Old 7/22/12, 12:44 PM
David C. Macy, CMI's Avatar
David C. Macy, CMI David C. Macy, CMI is offline
Certified Master Inspector
Default Discharge connection
I need you help on the drain termination from the water conditioning system to a trap?
Sorry about the blurry pic. The line is from the conditioning system (has the spray bottle on top)
If it is a problem, why?
Normal I see go to a floor drain with an air gap.
I did not the stains at the wall of the masonry.
Thanks!!
Discharge connection-219512-055-jpg   Discharge connection-219512-060-jpg
Need a home inspection in Pennsylvania? Check out InterNACHI's listing of Pennsylvania certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/22/12, 12:53 PM
Jeffrey R. Pope, CMI's Avatar
Jeffrey R. Pope, CMI Jeffrey R. Pope, CMI is offline
Certified Master Inspector ®
Default Re: Discharge connection
The connection should not be sealed. There should be an air gap (or at least an air break) between the discharge line and the vertical drain line.
The problems are (1) if that drain backs up, waste water can be forced into the filtration/treatment system and (2) without a gap, the discharge line can siphon waste water back into the filtration/treatment system.
A "break" will eliminate the potential for #1, while a "gap" eliminates both potentials.
IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE «
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 7/22/12, 1:00 PM
Thanks, I new it was wrong just wanted to be sure and you are about as reliable as it gets.
Thanks a lot US member of the year!! Make that decade (thats 10 years right)
I am doing an inspection for a client named Pope tomorrow, any relatives up this way?
Old 7/22/12, 1:06 PM
Marcel R. Cyr, CMI's Avatar
Marcel R. Cyr, CMI Marcel R. Cyr, CMI is offline
I got Jeff covered for next Year.
If Nick goes along with it.
Discharge connection-10-pin-jpg
CMI 2004-2017 Retired
Awards Committee Member
U.S. Member of the Year Winner 2009
45 Years Residential/Commercial Builder
Old 7/22/12, 1:07 PM
Michael Larson's Avatar
Michael Larson Michael Larson is online now
Pretty easy to fix with a standpipe air gap
As a Professional Home Inspector, I support the privacy of my clients.
You own your private information. I won't sell or give away yours, others do
www.InspectraPro.com
www.MinnesotaHomeInspector.biz
Michael Larson
Hudson, WI
Call me
Old 7/22/12, 1:31 PM
Attachment 57122
I am 18 months away from getting a 10 year pin. Jeff deserves more!!
Old 7/22/12, 1:32 PM
I was wondering were you obtained the air gap illustration from, I wish code check had one!!
Old 7/22/12, 2:35 PM
Same place you get the air gap.
Old 7/22/12, 3:23 PM
None that I'm aware of, but who really knows
Jeff Pope
Santa Clarita CA
(661) 212-0738
CILB jshishilla Florida Home Inspectors 73 6/13/12 6:54 PM
TPRV valve kblanchard Plumbing Inspections 16 1/19/12 9:22 PM
Can a TPR valve discharge to a water heater pan??? jfunderburk Plumbing Inspections 10 9/16/10 10:27 PM
What's this video worth? jtedesco1 Inspection Education & Training 5 4/18/08 9:24 AM
