Old 5/1/12, 10:12 PM
Juan C. Jimenez Juan C. Jimenez is offline
Default Small distribution piping
Can anyone help me with a narrative for this distribution piping. Its too small right? And what is that thing under the sink?Small distribution piping-1-264-jpg
Small distribution piping-whatisthis-jpg
Small distribution piping-distrubutionpiping1-jpg
Need a home inspection in New Hampshire? Check out InterNACHI's listing of New Hampshire certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/1/12, 10:13 PM
Default Re: Small distribution piping
I already know the TPR valve discharge pipe is crap.
Old 5/1/12, 10:54 PM
Christopher Currins, CMI Christopher Currins, CMI is offline
Certified Master Inspector ®
Clean-out/connection for cast iron drain pipe.
No water lines do not look too small from here. Typical 3/8".
Old 5/1/12, 11:17 PM
Charley L. Bottger's Avatar
If ya know all that ya know more than me the PEX is rated for hot water and its not reduced in diameter so where is the crap you see
http://www.oklahomathermalinfraredimaging.com/
http://www.freedomexpressinspections.com/
Master HVAC Mechanic Retired
Level III Thermographer # 8486 Infraspection Institute
CMI Certified Master Inspector
Residential/Commercial Inspections
Moisture Intrusion Expert Witness
Okla State License # 130
580-268-3340
Old 5/1/12, 11:24 PM
Stephen W. Stanczyk's Avatar
Stephen W. Stanczyk Stephen W. Stanczyk is online now
Darn you're fast Charley.
Stephen Stanczyk
Pierce County -Thurston County - King County - Kitsap County
Old 5/1/12, 11:28 PM
State of Virginia Plumbing Code 504.6 number 6.
Discharge in a Manner that does not cause personal injury.
The discharge pipe is very flexible. (A properly functioning TPR valve will eject a powerful jet of hot water from the discharge pipe when fully activated, not a gentle leak.) In my opinion that thing is going to move like a water house under high pressure and could injure someone.
Old 5/1/12, 11:34 PM
Jeffrey R. Jonas's Avatar
InterNACHI Applicant
Just how sure of that are you?
Jeffrey R. Jonas
Owatonna, Minnesota
Old 5/1/12, 11:38 PM
Thanks for your help Christopher.
Old 5/1/12, 11:58 PM
I think you are being peronid
580-268-3340
Old 5/2/12, 1:03 AM
Greg W. Mathias, CCHI, CMI's Avatar
Greg W. Mathias, CCHI, CMI Greg W. Mathias, CCHI, CMI is offline
I see no issue with it. You know if you call it up they will just strap it to the hot water heater. The pipe will not curl up and spray the entire area like a water hose.
Greg Mathias, CCHI
Journeyman Carpenter
Level I Thermographer
Global Property Inspections
(780)205-9912
Old 5/2/12, 1:15 AM
Maybe not curl up but it is easily moved by hand and has lots of play. Maybe it won't spray every where, maybe I am being paranoid. But i think a healthy amount of paranoia makes for a good inspector.
Old 5/2/12, 2:46 AM
Chuck Evans's Avatar
I would expend my energies elsewhere and avoid being embarrassed by the plumber who comes behind your report. The TPR discharge is fine. It's not going to whip around like a loose fire hose.
Chuck Evans (TREC #7657)
TheWoodlandsHomeInspection.com
Houston, TX
_______________________
Awards Committee Member
Old 5/2/12, 8:38 AM
KEVIN WOOD, CMI KEVIN WOOD, CMI is offline
Banned
Please Note: kwood is a non-member guest and is in no way affiliated with InterNACHI or its members.
The one elbow reduces the size but I am not to agreeable with the theory of the whiplash of hot blasted water. The PEX may be rated for 150 PSI and 210 F but some are not.
Reduction in the last 2 feet under the sink with 3/8" is fine.
Old 5/2/12, 8:54 AM
Banned
According to US I believe you can use 100 PSI and 180 F as a minimum but are not allowed to reduce in size and must have an air gap.
Old 5/2/12, 9:46 AM
Joe Funderburk, CMI's Avatar
Joe Funderburk, CMI Joe Funderburk, CMI is online now
I don't see anything out of the ordinary. The piping beneath the sink is definitely typical. Supply to the WH looks to be 1/2" which is fine. Strapping the TPR discharge would be good practice.
Theodore Roosevelt
Joe Funderburk, CBO, CMI
Angie's List Super Award Winner 2017, 2016, 2015, 2014, 2013, 2012, 2011, 2010.
Ph: 704-351-1776
www.aohomeinspection.com
Polybutylene Piping dbowers Plumbing Inspections 5 2/5/11 7:46 PM
Massachusetts Board of Registration of Home Inspectors jtedesco1 Legislation, Licensing, Ethics & Legal Issues for Inspectors 0 2/14/06 4:38 AM
