Old 4/3/13, 10:30 PM
Barry Adair's Avatar
Location: this side of Texas dirt, another successful day
Default edu intent: your thoughts as to cause
cold supply valve @ wh w/calcification
no leak present although it looks it
edu intent: your thoughts as to cause-dsc00082-jpg   edu intent: your thoughts as to cause-dsc00083-jpg
badair
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
National Association of Commercial Building Inspectors & Thermographers™ Member ID 12011-14TX
life is the random lottery of events followed by numerous narrow escapes...accept the good
Need a home inspection in Nebraska? Check out InterNACHI's listing of Nebraska certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/3/13, 10:34 PM
Greg W. Mathias, CCHI, CMI's Avatar
Greg W. Mathias, CCHI, CMI Greg W. Mathias, CCHI, CMI is offline
Certified Master Inspector ®
Default Re: edu intent: your thoughts as to cause
Condensation on the cold water line. Looks like they installed insulation on some of it but where it meets the valve there is none.
Greg Mathias, CCHI
Journeyman Carpenter
Level I Thermographer
Global Property Inspections
(780)205-9912
Old 4/3/13, 10:51 PM
Dale Duffy's Avatar
Ummm...Faulty (way south of the border) Brass?????.....
Old 4/3/13, 10:55 PM
Wayne B. Wilson, TN 439's Avatar
Wayne B. Wilson, TN 439 Wayne B. Wilson, TN 439 is online now
I would say it was leaking and sealed itself up.
Wayne Wilson CMI
East TN Home Inspections LLC
865-256-1490
https://www.myhomeinspection.net/
Old 4/3/13, 11:34 PM
Jeffrey R. Jonas's Avatar
InterNACHI Applicant
The fact the ground conductor has "patina" supports the condensation/prior leak theory. Looking closely, I suspect it may have been cleaned of some of the buildup at some point.
Jeffrey R. Jonas
Owatonna, Minnesota
Old 4/3/13, 11:45 PM
Bob Elliott's Avatar
If stray electrical current travels through a copper water main it will usually rot out in a year or so and then leak.
That looks like it may be a electric water heater and there is a ground there as well.
If this is being caused by electroysis I would add a dielectric coupling so the rubber could act as an electrical break.
Old 4/3/13, 11:47 PM
William Warner's Avatar
William Warner William Warner is offline
Spray some battery terminal cleaner on it and call it a day...
Old 4/4/13, 12:54 AM
Chuck Evans, TREC 7657's Avatar
Chuck Evans, TREC 7657 Chuck Evans, TREC 7657 is online now
IIRC from my plumbing days, brass is universal and can be connected directly to copper or steel piping without a separate dielectric. BTW: dielectric couplings are only minimally effective at reducing galvanic corrosion because the water inside the pipe is, itself, an electrolyte
Methinks its a porous brass casting that leaks through the pores at a microscopic rate. Possibly due to dezincification or just poor casting. It's close enough to the heater that the minuscule amount of water that gets through evaporates, leaving the dissolved minerals from the water behind. I see this often in Texas attics.
I think the green on the bonding wire is due to exposure to the acid flux from the adjacent sweated joint.
Chuck Evans (TREC #7657)
TheWoodlandsHomeInspection.com
Houston, TX
_______________________
Awards Committee Member
Old 4/4/13, 1:56 AM
Dale Duffy's Avatar
Thank You.....
Old 4/7/13, 11:51 PM
Scott May, CMI CCHI's Avatar
Scott May, CMI CCHI Scott May, CMI CCHI is online now
Send a message via Skype™ to smay
Agree with Chuck, upon looking at pic 2 there was moisture below and from the direction of the build up it appears to be coming from the threaded fitting with the nut (left)...maybe just needs tightening or...maybe ready to blow. JMO
Try not to become a man of success but rather to become a man of value!
Any information posted by me on this site should be considered as a personal opinion, belief or assumption and cannot be attributable by way of association to any other company, person or agency.
Serving: Acton, Burlington, Brampton, Cambridge, Durham, Erin, Guelph, Georgetown, Hamilton, Kitchener, Mississauga, Oakville, Waterloo
T200/T250 Thoughts? rking6 Thermal Imaging, Infrared Cameras & Energy Audits 3 6/25/10 8:48 PM
Reminder: The original intent of this MISC forum... gromicko Miscellaneous Discussion for Inspectors 29 3/17/08 9:11 PM
