Old 2/14/13, 8:12 PM
Mike G. Krueger, 2344 Mike G. Krueger, 2344 is offline
Default Is a firestop required? Is this the correct code ref?
Radon mitigation system going through the common wall (residential - house/garage) and through the drywall ceiling of the attached garage with no firestop/collars. Is this the correct code reference? If so what would be an example of "firmly packed with noncombustible material"?
321.08 3(b) Electrical and plumbing components. Penetrations of a
required separation by electrical and plumbing components shall
be firmly packed with noncombustible material or shall be protected
with a listed through−penetration firestop system with a rating
of at least one hour.
Thank you
Need a home inspection in New York? Check out InterNACHI's listing of New York certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/14/13, 8:18 PM
Michael Larson's Avatar
Michael Larson Michael Larson is online now
Default Re: Is a firestop required? Is this the correct code ref?
http://solutions.3m.com/wps/portal/3...be0HVGSP8767gl
As a Professional Home Inspector, I support the privacy of my clients.
You own your private information. I won't sell or give away yours, others do
www.InspectraPro.com
www.MinnesotaHomeInspector.biz
Michael Larson
Hudson, WI
Call me
Old 2/14/13, 10:58 PM
Michael, the wall penetration was sealed with a clear sealant (not sure if it is fire rated though). My question is if fire rated sealant is used what happens when the pvc pipe melts. A fire collar is suppose to close the opening.
Old 2/16/13, 3:10 PM
Mark S. Tyson, CGC1516843 Mark S. Tyson, CGC1516843 is offline
Mike,
You are getting your oranges mixed in with your apples. A one hour rated fire wall is not required in a single family detached home between the house and an attached garage. On single family it is a 20 minute rated wall.
If duct were to pass through it would currently (not always in the past) have to be no less than no.26 gauge sheet metal. Other penetrations can pass through one but not both sides of the wall and be sealed with a material that prevents the free flow of smoke or flame but need not meet the requirements of ASTM E 136.
One hour walls are typically required at the tenant separation walls off attached Townhouses
Mark S. Tyson
M Tyson construction LLC
Tyson Home Inspections
Certified General Contractor #1516843
Florida Licensed Home Inspector #1824
Member N.A.C.H.I.
IAC2 certified
Member Florida Building Officials Association
http://www.TysonHomeInspections.com
Wind Mit Experts adeerey Florida Home Inspectors 21 12/23/11 3:49 PM
Where is it written.... bgromicko General Inspection Discussion 21 1/19/08 9:02 PM
