Old 4/2/13, 6:18 PM
Eric Flocco Eric Flocco is offline
Please Note: Eric Flocco is a non-member guest and is in no way affiliated with InterNACHI or its members.
Question Is flex gas line allowed to run from basement to 2nd floor furnace??
House was built in 2001 - Sewell, NJ (south NJ)
there is a flexible yellow gas line that runs from the basement up to the 2nd floor furnace in the attic
Is this code compliant?? if not now, any way to find out if it was back in 2001?
Any help/info would be greatly appreciated
I am a homeowner, not an inspector---thanks!!
Eric
Need a home inspection in Mississippi? Check out InterNACHI's listing of Mississippi certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/2/13, 7:52 PM
Larry Kage, CMI's Avatar
Larry Kage, CMI Larry Kage, CMI is offline
Certified Master Inspector ®
Default Re: Is flex gas line allowed to run from basement to 2nd floor furnace??
It sounds like CSST (Corrugated Stainless Steel Tubing) and if designed, installed and bonded correctly shouldn't be a problem.
http://www.gastite.com/page.php?pg=t...s&idlink=link6
Awards Committee Officer
SUBMIT YOUR AWARD NOMINATIONS HERE:
http://co.nachi.org/inachiawards/
The InterNACHI Awards Committee is the final authority of the issuance of any award the committee offers and any rules interpretation updates.
Larry Kage, CMI Lifetime Member
State Licensed Builder since 1973
InterNACHI Lifetime Member
~retired~
The above post represents my personal opinion.
Old 4/2/13, 9:44 PM
Thank you Mr. Cage for the reply and the link - very helpful
Eric
Old 4/2/13, 10:00 PM
Bob Elliott's Avatar
Read what Larry gave you and make sure it is bonded.
Old 4/2/13, 10:08 PM
Gary Farnsworth, CMI's Avatar
Gary Farnsworth, CMI Gary Farnsworth, CMI is offline
Check local codes. Here, it cannot run through a wall. That is for solid black pipe.
Certified Master Inspector, Retired
Formerly Serving the Greater Kansas City Metro Area
Lifetime InterNACHI Member
"If opportunity doesn't knock, build a door"--Milton Berle
Old 4/2/13, 10:22 PM
Jamin M. Jones's Avatar
Jamin M. Jones Jamin M. Jones is offline
Default Is flex gas line allowed to run from basement to 2nd floor furnace??
It's called "Trac Pipe" and was very common until maybe 2009 They now use a black product called "Counterstrike" here is the guide for the yellow stuff. Should have all detail and installation factoids you want. http://www.tracpipe.co.za/DIGuide.pdf
Old 4/2/13, 10:24 PM
The yellow had some sort of lighting strike issue if not grounded properly.
Old 4/2/13, 10:27 PM
Jeffrey R. Pope, CMI's Avatar
Jeffrey R. Pope, CMI Jeffrey R. Pope, CMI is offline
CSST can run through walls, just like black pipe.
IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE «
Jeff Pope
JPI Home Inspection Service
(661) 212-0738
Los Angeles, Santa Clarita & Antelope Valley CA
Old 4/3/13, 12:04 AM
Great stuff.
When it runs behind your living room wall no anchors are needed.
Just drywall screw it in and the screw self seals it.
If burglers enter you just yank the screw and light a match and have fun watching them run.
lol seriously though it never caught on real big here and I am glad of it.
Old 4/3/13, 11:39 AM
Thanks again for all the input - i spoke with the local inspector who confirmed it was installed to code
can't thank you all enough for helping - great site!!
Eric
Old 4/3/13, 1:32 PM
Michael Larson's Avatar
Michael Larson Michael Larson is online now
Also, no fittings are allowed to be concealed for ANY type of gas pipe in my area even when the fitting is rated for concealment.
Don't ask how I know.
As a Professional Home Inspector, I support the privacy of my clients.
You own your private information. I won't sell or give away yours, others do
www.InspectraPro.com
www.MinnesotaHomeInspector.biz
Michael Larson
Hudson, WI
Call me
Old 4/3/13, 1:36 PM
I assume you mean flex as it would need to have allowances for regular elbows and tee's.
Old 4/3/13, 1:57 PM
When I said ANY, I meant it.
From my local AHJ.
Michael Larson
Hudson, WI
Call me
Old 4/3/13, 3:06 PM
From my local AHJ.
So when they pipe high rises they find 20 story long pipe...
Must be some pretty bad az plumbers up north.
Old 4/3/13, 3:07 PM
Listen, I think my AHJ is wrong that doesn't mean I can ignore what he says.
Michael Larson
Hudson, WI
Call me
Gas flex line in crawl space Richard Seay Plumbing Inspections 19 8/12/08 8:12 PM
Basement Bathroom Venting Question Sean M. Jeric Plumbing Inspections 4 3/20/07 11:56 PM
Exposed Flex Gas Line jfunderburk Plumbing Inspections 20 5/11/06 1:44 AM
TPRV line and condensate line marriage ccarrington Plumbing Inspections 3 4/29/06 7:59 AM
