Old 12/1/12, 5:14 PM
Gary Heller's Avatar
Gary Heller Gary Heller is offline
Default Garbage Disposal on a septic system
I retired and moved to a rural setting in Prescott Valley. Our new house has a septic and a garbage disposal. Should I be worried?
Garbage Disposal on a septic system-002-jpg
Gary Heller
928-910-9175
www.inspectingprescott.com
Need a home inspection in Colorado? Check out InterNACHI's listing of Colorado certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/1/12, 5:20 PM
Stephen W. Stanczyk's Avatar
Stephen W. Stanczyk Stephen W. Stanczyk is online now
Default Re: Garbage Disposal on a septic system
There are disposals designed for septic tanks. No problem with those. With regular disposals, the grind is larger and takes longer to break down in the tank.
In the long run, as long as you don't go overboard with what you put down the disposal, it won't bother it. If you put all your potato or carrot peels, coffee grounds, egg shells and used food down the disposal, then you will have issues.
Get some chickens instead.
Stephen Stanczyk
Pierce County -Thurston County - King County - Kitsap County
Old 12/1/12, 5:24 PM
Roy D. Cooke, Sr's Avatar
I see little difference putting the cabage through the Disposal or through my stomach all ends up in the same place,
Old 12/1/12, 5:27 PM
Larry Kage, CMI Larry Kage, CMI is offline
Certified Master Inspector ®
The difference is that it gets digested first going through most stomachs, whereas it is still raw until it gets decomposed in the tank.
We have a septic system with a disposal and, like Stephen said, don't go hog wild with what you put down there. We use a compost pile and our garden loves it...
Awards Committee Member
SUBMIT YOUR AWARD NOMINATIONS HERE:
http://co.nachi.org/inachiawards/
Larry Kage, CMI 2004-2017
State Licensed Builder since 1973
InterNACHI Lifetime Member
~retired~
The above post represents my personal opinion.
Old 12/1/12, 5:33 PM
That's what the bacteria does in septic tank or in my Fish tank filter it eats the poo or the leftover food.
Old 12/1/12, 5:35 PM
Michael Larson's Avatar
Michael Larson Michael Larson is online now
Not a good idea unless the tank is oversized and the material going in very well ground.
As a Professional Home Inspector, I support the privacy of my clients.
You own your private information. I won't sell or give away yours, others do
www.InspectraPro.com
www.MinnesotaHomeInspector.biz
Michael Larson
Hudson, WI
Call me
Old 12/1/12, 5:36 PM
Correct. But if it is raw food, and not digested through your stomach first, it decomposes more slowly and builds up and potentially clogs things.
~retired~
Old 12/1/12, 5:38 PM
James F. McKee's Avatar
James F. McKee James F. McKee is online now
It's no problem as long as You don't use it Gary...at least that is what my septic guy says. If you choose to use the disposal plan on more frequent pumpings and service to Your tank...
Jim McKee
Amherst, Ohio
440 225 8688
www.amhersthomeinspector.com
Old 12/1/12, 5:50 PM
Exactly we have many agents who say you never need to pump your tank. When the client asks me I say that is correct never pump your tank and you might have to replace it in about ten+~ years and the cost can be up too $25,000.00 .
Those who pump their tank frequently seem to last a very long time .
I think it is best to spend $250;00+~ every 2 to 5 years depending on usage and how many people are in the home.
Old 12/1/12, 6:13 PM
Peter C. Russell's Avatar
Garbage disposals are not good for septic system as stated above but more because the ground up food becomes suspended in the liquid layer of the tank and will migrate out to the EDA clogging the drain field. The treatment tank is made up of three layers, the bottom or sludge layer, the liquid layer in the middle and the floating scum mat on top. The problem with food particles from a disposer is they don't sink and don't float. This allows them to move with the effluent out into the EDA.
Here in NH, if you want a garbage disposer you need to increase the tank size by 50%, in Maine you have to install an effluent filter in the outlet baffle.
The problem with effluent filters and garbage disposers is they tend to clog very easy and have to be cleaned on a regular basis.
Normal pumping for treatment tanks is when the sludge layer makes up more than 1/3 the total volume of the tank. Usually every two years for a family of 4-5.
Russell Inspection Services LLC
New Hampshire state license # 57
New Hampshire licensed septic evaluator # 18
Level II Thermographer, ITC
Building Science Thermographer, ITC
Commercial Inspector, ITA
www.newenglandthermalimaging.com
www.russellinspectionservices.com
www.nhsepticinspection.com
www.nh-commercial-building-inspector.com
Serving Alton, Alton Bay, Wolfeboro, Laconia, Gilmanton, Gilford, Meredith, Center Harbor and the entire Lakes Region
Old 12/1/12, 6:20 PM
Marcel R. Cyr, CMI's Avatar
Marcel R. Cyr, CMI Marcel R. Cyr, CMI is offline
Well said Peter, that was my understanding of the question also, about garbage disposals and septics.
CMI 2004-2017 Retired
U.S. Member of the Year Winner 2009
45 Years Residential/Commercial Builder
Old 12/1/12, 10:11 PM
Chuck Evans's Avatar
I've had an onsite wastewater treatment system with a disposer for over eight years. We use it very sparingly, usually on stuff that's too runny to go in the trash. All other garbage goes in the can. We have had no problems and have had very slow sludge accumulation.
As others have said, use it minimally and only with digestible food waste.
Chuck Evans (TREC #7657)
TheWoodlandsHomeInspection.com
Houston, TX
Old 12/1/12, 11:07 PM
Marcel Gratton, CMI's Avatar
Marcel Gratton, CMI Marcel Gratton, CMI is offline
If a garburator would have been used when my septic was installed years ago, leaching bed length would have had to be double.
On The Level Inspection
Gatineau, Québec
Old 12/2/12, 8:58 PM
Just install one of these and your good to go, fresh citrus scent too.
Garbage Disposal on a septic system-ducharme-095-jpg
Old 12/2/12, 9:31 PM
Peter, I have that Brand, is that one made specifically for septic systems?
Garbage Disposals & Septic Systems jkeilson Plumbing Inspections 16 11/5/11 8:46 AM
My second well and first septic system in Toronto of all places! mkyriacou Plumbing Inspections 3 6/13/09 9:48 PM
What to tell your clients when they have a septic system. Watch the new episode now gromicko Miscellaneous Discussion for Inspectors 13 3/28/09 2:43 PM
Understanding Your Septic System rcooke Plumbing Inspections 8 1/9/08 8:29 AM
