Old 4/25/12, 9:08 PM
Brad Brinke, CMI's Avatar
Brad Brinke, CMI Brad Brinke, CMI is offline
Certified Master Inspector
Default Hot toilet
How many times do you see this?
Hot toilet-ir000847-jpg
Inspecting Norfolk and Hampton Roads
www.procraftinspections.com
HERS Rater, Board Certified Mold Inspector
Trustworthy.
Need a home inspection in Michigan? Check out InterNACHI's listing of Michigan certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/25/12, 9:26 PM
Joseph Hagarty, CMI's Avatar
Joseph Hagarty, CMI Joseph Hagarty, CMI is offline
Certified Master Inspector ®
Default Re: Hot toilet
You are suggesting a hot water supply connection to a toilet?
I have seen it...
clients have their reasons.....
Usually Well Water to the Home and a Hot Water connection reduces condensation on the tank.
Joe Hagarty
mrdryervent@gmail.com
Cell: (484) 883-7018
Boulder, Colorado
Certified CMI Master Inspector Instructor
PA NACHI Certified Inspector # 01102902
PA Licensed Radon Inspector # 2080
PA Licensed Pesticide Applicator # 700884
Delaware Licensed Home Inspector # H4-071
Old 4/25/12, 9:41 PM
Ron Chorey II's Avatar
Ron Chorey II Ron Chorey II is offline
My question is why is the line to the tank from the supply line blue? I am not a thermal image nut but doesn't blue mean cold n the presence of red? How come it stops/ I guess I need some edumecation!!
Ron Chorey
LAS CRUCES Home Inspections,LLC
Las Cruces NM
88005
575-640-0795
NACHI Membership 04070981
www.lascruceshomeinspections.com
Old 4/25/12, 9:44 PM
Plus there is a 60 degree temperature difference between what appears to be water connection. A regular picture with this IR pic would have been better to understand what you are looking at..
Ron Chorey
Las Cruces NM
88005
575-640-0795
Old 4/25/12, 10:39 PM
Sean Fogarty's Avatar
I have had several of these and not all are hot water. Did you actually look at the temperature?
I had one situation where the mixing valve for the shower was bad and allowing enough bypass to show up like that, but the supply was correct.
I also had others that simply look warmer due to the fact the water is warmer than the inside of the home.
Could it just be the fact that your warm body is reflecting off the metal line???
What was your conclusion to this image?
Fogarty Inspection Services Group of Palm Bay FL
FL Licensed Home Inspector #8351
Infraspection Level 2 Thermographer #8788
FL Licensed Mold Assessor #MRSA2330
Home inspections, Commercial Inspections, Mold assessments, Thermal Imaging, Wind Mitigation and Insurance Inspections for Palm Bay, Melbourne, Cocoa, Titusville, Vero Beach and all the surrounding areas.
321-506-5125
fogartyinspectionservices@gmail.com
www.homeinspectorpalmbay.com
Old 4/25/12, 10:46 PM
The temp scale on the right shows the temp of that line at 127 degrees. I felt it first and then got the camera out for fun. I flushed the toilet and watched the temp and image change from cold to hot. My conclusion to this image is that the plumber hooked up hot water to this toilet and said water is being flushed down the drain. Conclusion out
Trustworthy.
Old 4/25/12, 11:01 PM
127 would be hot water. Good conclusion!
321-506-5125
Toilet clearance srinner General Inspection Discussion 7 7/11/09 12:38 AM
Basement toilet bubbles from air btreacy Plumbing Inspections 9 12/6/08 1:12 PM
My toilet won't flush Matt Piercy Plumbing Inspections 22 9/28/07 3:27 PM
Toilet in bedroom!? ngifford Plumbing Inspections 14 2/19/06 12:43 AM
