Old 5/22/12, 6:43 PM
Ron W. Cleland, CMI's Avatar
Ron W. Cleland, CMI Ron W. Cleland, CMI is offline
Certified Master Inspector ®
Default Hot Water Heater Venting
Came across this today and not sure what to make of it. It appears to be some type of a damper. The metal box is open at the bottom and it looks like some sort of a damper inside. Although it does not seem to open or close. Is this some type of a air intake? Notice there is no bonnet on top of the water heater.
Hot Water Heater Venting-100_4142-jpg   Hot Water Heater Venting-100_4144-jpg
Ron Cleland, CMI
Hutchinson, MN.
Providing Peace of Mind
to Buyers and Sellers
Serving West Central MN.
1stclasshomeinspectionllc.com
facebook.com/1stclasshomeinspection
Watch My 60 Second Video
Need a home inspection in New York? Check out InterNACHI's listing of New York certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/22/12, 6:45 PM
Michael Larson's Avatar
Michael Larson Michael Larson is online now
Default Re: Hot Water Heater Venting
Why is there no draft hood on the water heater?
As a Professional Home Inspector, I support the privacy of my clients.
You own your private information. I won't sell or give away yours, others do
www.InspectraPro.com
www.MinnesotaHomeInspector.biz
Michael Larson
Hudson, WI
Call me
Old 5/22/12, 6:55 PM
Exactly! Looks like a Do It Yourselfer...
Ron Cleland, CMI
Hutchinson, MN.
Old 5/22/12, 7:03 PM
Chris Walsh, CMI's Avatar
Chris Walsh, CMI Chris Walsh, CMI is offline
Is it possible that the metal box acts as a draft hood? Never seen this setup before.
Old 5/22/12, 10:10 PM
William T. Misegades William T. Misegades is offline
If the base of the box is open, the carbon monoxide will come right back into the room...
Also, where did the TPR valve extension go? Was it in the wrap insulation? Missing shutoff valve. It all looks like DIY work.
Where there is a Will there is a Way!
Will Misegades
TREC# 10465
RedFish Home Inspections
www.redfishinspections.com
Infraspection Institute Certified Infrared Thermographer Level I # 9631
"it's not just about how to turn on and tune the camera to make pretty colored spots!"
David A. Andersen, Woodlawn, TN
Old 5/23/12, 12:10 AM
The 2 into 1 "Y" connection looks like a DIY job as well.
Client wants a new water heater adirienzo General Inspection Discussion 47 7/14/10 2:03 PM
Site grading and drainage wdevries Canadian Home Inspectors 5 10/6/09 10:23 PM
Sulphur smell bsmith Plumbing Inspections 2 6/6/08 8:32 PM
Venting an oil-fired water heater mh718 Inspecting HVAC Systems 3 11/16/06 9:36 AM
