Old 5/16/18, 9:05 AM
Brian C. Schaefer, bschaefer Brian C. Schaefer, bschaefer is offline
Default Insulation blanket on heater
Hello All. Just wanted to present a discussion point about insulating a water heater with a secondary blanket. These are able to be purchased at various box stores and at first thought to the average consumer, is a wise decision. However, this is not recommended by most manufactures as today's unit's exceed the NAECA standards. This excerpt is from Rheem's installation manual:
"Insulation blankets, available to the
general public, for external use on gas
water heaters are not necessary. The
purpose of an insulation blanket is to
reduce the standby heat loss encountered
with storage tank heaters. This water
heater meets or exceeds the National
Appliance Energy Conservation Act
standards with respect to insulation and
standby loss requirements making an
insulation blanket unnecessary.
The manufacturer’s warranty does not
cover any damage or defect caused by
installation, attachment or use of
any type of energy saving or other
unapproved devices (other than those
authorized by the manufacturer) into, onto
or in conjunction with the water heater.
The use of unauthorized energy saving
devices may shorten the life of the water
heater and may endanger life and property.
The manufacturer disclaims any
responsibility for such loss or injury.."
What's even more interesting is that our very own NACHI recommends installation of this in the "How to Perform Energy Audits" course. In Section 19, "Home Owner Checklist", it reads, "Check to see if your water heater has an insulating blanket. An insulating blanket will pay for itself in one year or less!".
I'm not trying to crack on NACHI, but this clearly suggest that a blanket should be installed. My question is, if installed and failure happens, I would assume most "home warranties" would also disclaim coverage. That leaves the home owner asking their friendly inspector as to why this wasn't brought up. Although we do not determine manufacture or warranty coverage, it's still a call that you don't want.
So when you see a blanket, suggest it be removed, not added.
Need a home inspection in Oklahoma? Check out InterNACHI's listing of Oklahoma certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/16/18, 9:11 AM
Roy Lewis, CMI's Avatar
Roy Lewis, CMI Roy Lewis, CMI is online now
Certified Master Inspector ®
Default Re: Insulation blanket on heater
It has been proven the blanket are not worth it.
InterNACHI Lifetime Member.
www.1stproinspection.com
roy@1stproinspection.com
Serving Gainesville Florida and surrounding areas.
Florida Certified Contractor #CRC1328001
Florida Certified Home Inspector #HI7019
Deus solus me iudicare potest
#1st Pro Inspection
Well! They may have degrees, but that is not an indicator of common sense or right thinking...M. Larson circa 9-27-2018.
Old 5/16/18, 9:29 AM
Joshua L. Frederick Joshua L. Frederick is online now
I agree insulation blankets are gimmicky...then again, what isn't now in this profession?
http://northwestohiohomeinspector.com
Defiance home inspector
Northwest Ohio home inspector
Old 5/16/18, 9:30 AM
And just because INachi says something or offers an opinion, it doesn't necessarily make it so
Old 5/17/18, 12:04 AM
Chuck Evans's Avatar
There are many things that have found their way into iNACHI training that aren't quite accurate. The training is still very valuable and worthwhile, but not everything should be taken as gospel.
Chuck Evans (TREC #7657)
The Woodlands Home Inspections
Magnolia TX Home Inspections & Thermography
Houston, TX
_______________________
Awards Committee Member
Old 5/17/18, 1:06 AM
Stephen W. Stanczyk's Avatar
Stephen W. Stanczyk Stephen W. Stanczyk is online now
There was a thread in here a while back that discussed the thoughts that installing an insulating blanket actually cost money and didn't save it. Found it. Interesting reading.
WH blanket
Stephen Stanczyk
RETIRED
Pierce County -Thurston County - King County - Kitsap County
