Old 12/15/12, 11:30 PM
Kenneth R. Brittain's Avatar
Kenneth R. Brittain Kenneth R. Brittain is online now
Default Just Because
It was there
Just Because-tub-jpg
Need a home inspection in New Hampshire? Check out InterNACHI's listing of New Hampshire certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/16/12, 9:26 AM
KEVIN WOOD, CMI KEVIN WOOD, CMI is offline
Banned
Please Note: kwood is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Just Because
Because Poly said so!
Old 12/16/12, 9:31 AM
Joshua L. Frederick Joshua L. Frederick is online now
Red Dura-Pex as well?
Old 12/17/12, 6:20 AM
Mike Auger's Avatar
Mike Auger Mike Auger is offline
Certified Master Inspector ®
Originally Posted by kbrittain View Post
It was there
were you inspecting the home of dr. suess
Mike Auger, CMI
RI Reg. # 32856
RI Radon Lic. # RMC-142 RMB-096
(401) 578-4878
A U.S.A.F. Veteran Owned Company
Old 12/17/12, 8:45 AM
Now it does look like something from a Dr Suess book.
Old 12/18/12, 5:35 PM
Bruce R. Grant Bruce R. Grant is offline
It looks to me like someones attempt to set up a tempering system for a whirlpool fill. Red pex is common here on newer installations, used to indicate hot side, blue is used for cold.
Bruce Grant
Done Right Home Inspections
Washago Ontario Canada
http://www.muskokahomeinspection.ca/
http://www.orilliahomeinspector.biz/
Old 12/21/12, 8:43 AM
This is the creation of a Licensed Plumber.
Old 12/21/12, 8:57 AM
Eric C. Van De Ven, CMI Eric C. Van De Ven, CMI is online now
It was there
It looks like the hot and cold routed to a hand sprayer. Since the poly was already there, he stuck with the same type of materials.
