Old 8/21/18, 9:18 PM
Joshua LeBeau's Avatar
Joshua LeBeau Joshua LeBeau is offline
Default Leaking Well valve??
This section of plumbing hardware is dripping.
This is part of a well water assembly. It is threaded on the inside.
Is it a bleed valve?
Any help would be appreciated.
Thanks, Josh
Leaking Well valve??-inked2018-7-21-55_li-jpg   Leaking Well valve??-inked2018-7-21-56_li-jpg
Joshua & Michelle LeBeau
www.HomeInspectionsbyJML.com
Need a home inspection in Colorado? Check out InterNACHI's listing of Colorado certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 8/22/18, 6:29 AM
Roy Lewis, CMI's Avatar
Roy Lewis, CMI Roy Lewis, CMI is online now
Certified Master Inspector ®
Default Re: Leaking Well valve??
I can't get the picture to load?
InterNACHI Lifetime Member.
www.1stproinspection.com
roy@1stproinspection.com
Serving Gainesville Florida and surrounding areas.
Florida Certified Contractor #CRC1328001
Florida Certified Home Inspector #HI7019
Deus solus me iudicare potest
#1st Pro Inspection
Well! They may have degrees, but that is not an indicator of common sense or right thinking...M. Larson circa 9-27-2018.
Old 8/22/18, 7:34 AM
Joshua L. Frederick Joshua L. Frederick is online now
Roy's right, pics not loading or "blowing up" for some reason? Anyway, looks like a leaky pressure relief valve to me...very common.
YouTube
http://aspecresidential.com
Defiance home inspector
Northwest Ohio home inspector
Old 8/22/18, 8:56 AM
The pictures have "Ink" annotations, that is probably why they cannot load.
Here are the originals.
Leaking Well valve??-2018-7-21-56-jpg   Leaking Well valve??-2018-7-21-55-jpg
Old 8/22/18, 9:00 AM
YouTube
Yep!
#1st Pro Inspection
