Old 10/11/08, 11:06 PM
Rick Maday's Avatar
Rick Maday Rick Maday is offline
Please Note: rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Life expectancy of well pumps?
How bout this one?
Life expectancy of well pumps?-dsc00390-jpg   Life expectancy of well pumps?-dsc00391-jpg   Life expectancy of well pumps?-dsc00402-jpg
Old 10/11/08, 11:14 PM
Dale Duffy's Avatar
Default Re: Life expectancy of well pumps?
The pump looks new, the rest of the system is shot---
Old 10/11/08, 11:16 PM
Dale Duffy's Avatar
I'll take that back, the tank should have the rust brushed off and painted---
Old 10/11/08, 11:24 PM
Marc D. Shunk's Avatar
Banned
Somebody went to a lot of effort to make a nice nylon base for the pump motor and used Kynar piping for the pump, but didn't sit the tank on anything to keep it from drawing damp and rusting out.
Old 10/12/08, 7:57 AM
David A. Andersen, TN HI# 40's Avatar
David A. Andersen, TN HI# 40 David A. Andersen, TN HI# 40 is offline
The tank is on a vinyl tiled floor. They rust out because the cold water causes condensation on the outside of the tank. That moisture below the tank on the floor is most likely condensation.
"working together to get-IR-done" Chris Walsh
Bracebridge, Ontario:
BPI# 5015804
Old 10/12/08, 8:06 AM
David P. Valley's Avatar
Certified Master Inspector
Simply recommend the condensation pipes be placed into a condensation pump and have the rusted tank sanded and painted.
Old 10/12/08, 8:45 AM
Linas Dapkus, CMI's Avatar
Linas Dapkus, CMI Linas Dapkus, CMI is online now
Certified Master Inspector ®
The newer steel tanks are thin and do rust through. I had one that lasted about 5 years and sprung a leak. I replaced it with a spun fiberglass composite tank.
Linas Dapkus, CMI & LEO wannabe
Dapkus Home Inspections
Go away Rosie. You haven't had anything useful to say since you lost your mind when Trump won.
You are such a loser.
For God so loved the world that he gave his one and only Son, that whoever believes in him shall not perish but have eternal life.
TRUMP/PENCE 2020
https://i.imgflip.com/1z058y.jpg
Old 10/12/08, 10:53 AM
Joseph Hagarty, CMI's Avatar
Joseph Hagarty, CMI Joseph Hagarty, CMI is offline
http://www.inspect-ny.com/water/Pump_Life.htm
Jet Pump Life Expectancy:
An above-ground one line (shallow well) or two line (deep well) jet pump often operates for a considerable range of years, as few as 4 years or as many as 15 or 20 years before needing replacement.
A typical well pump life expectancy (lumping both the electric pump motor and the pump assembly together) is about 10 years in the U.S. and Canada, and about 5 years in Mexico and Central America.
Joe Hagarty
mrdryervent@gmail.com
Cell: (484) 883-7018
Boulder, Colorado
Certified CMI Master Inspector Instructor
PA NACHI Certified Inspector # 01102902
PA Licensed Radon Inspector # 2080
PA Licensed Pesticide Applicator # 700884
Delaware Licensed Home Inspector # H4-071
Old 10/12/08, 8:53 PM
jkogel jkogel is offline
The label says '88 for the tank, so it's in reasonable shape. Looks like there is a metal ring under it, which is what's rusting out.
Old 10/12/08, 9:04 PM
Joe Farsetta's Avatar
Joe Farsetta Joe Farsetta is offline
Pump life expectancy figures are directly related to the number of cycles per hour the pump facilitates. As Joe H stated, the pump can last 3 years or 30.
Pumps and associated systems (tanks) are a matched set, and should be sized for the specific application, calculating around 6 cycles per hour as optimal.
Old 10/12/08, 11:17 PM
Jack L. Gilleland's Avatar
Jack L. Gilleland Jack L. Gilleland is offline
Rick my rule of thumb with a pump was let sleeping dogs lie. If it works.......... I personally have seen pumps (belt driven that sounded like an HVAC tech vac. pump) work great. Try telling a farmer he has to replace his well pump because it is old. Rather pick a fight with his 2 great danes. Let him know that due to age he might consider budgeting for a new one.
In the world view we are all important and our mere existence effects all life.
Jack Gilleland
Home Inspection Services Clayton
Commercial, Multifamily, and Residential
jgilleland1@att.net
Ohio_Commercial and_Home_Inspections
linkedIn
activerain
Old 10/13/08, 10:48 AM
Wow Jack! Your daring!!
In this forum of "How old is this A/C etc.?", Are you going to get a reddie ?
I agree with you, but then I won't even answer the QOD on equipment age because age has nothing to do with anything. If it makes noise, my ampmeter and IR will tell me all I need to know. It is outside the SOP, but I feel safer outside than working off age.
BPI# 5015804
Old 10/13/08, 1:28 PM
So David you mandate a change of the pump if it reaches a certain age even if it seems to be working correctly? Not drawing an increased amount of amps. I wont go in and tell someone a change has to be made because the unit is 10 - 12 years old. I will give them the facts, indicators and explain.
Jack Gilleland
jgilleland1@att.net
linkedIn
activerain
Old 10/13/08, 7:06 PM
In this particular situation, it's very easy to CYA.
Simply report that the tank was operating as expected, with no obvious defects noted at time of inspection. However, due to systems age, it is clearly beyond it’s life expectancy, so a professional repair of the rusted areas or replacement should be considered soon.
Old 10/13/08, 9:22 PM
"Let him know that due to age he might consider budgeting for a new one."
Isn't that what I said?
Jack Gilleland
jgilleland1@att.net
linkedIn
activerain
Normal Life Expectancy jmckenna1 Miscellaneous Discussion for Inspectors 6 1/29/07 10:57 PM
Roof life expectancy cthorsen Exterior Inspections 20 9/18/06 8:25 PM
