Old 2/13/18, 8:29 AM
Frank Rotte Frank Rotte is offline
Default List of States allowing dishwasher air gap
I'm trying to put together a comprehensive list of the States that require an air gap on the dishwasher, and those that will accept a high loop. I have already entered information for California and Utah, because I know those two. Please go to the link and add your information. Thanks for participating.Is a dishwasher air gap required in your State - Google Docs
Certified Inspection Services, LLC
5521 Mission Road #1422, Bonsall, CA 92003
Check out the HG User Group on FB
ITC Certified Level I Thermographer
Need a home inspection in Nevada? Check out InterNACHI's listing of Nevada certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/13/18, 8:37 AM
Jeffrey R. Jonas's Avatar
Default Re: List of States allowing dishwasher air gap
Frank, what is the purpose/intended use for this list?
Jeffrey R. Jonas
Owatonna, Minnesota
Old 2/13/18, 8:52 AM
I just think it's useful information for comparison. I haven't decided yet how to use it. But when I was looking for this information, it wasn't available in one place.
Old 2/13/18, 9:05 AM
John Olson John Olson is online now
When did it become code? Is it a defect or a code violation?
Wisconsin is above or below the countertop. Below is a standpipe.
Old 2/13/18, 9:06 AM
Ok, but in my opinion, it is not entirely useful unless it contains all the facts. In example, MN did not require Air Gaps until Jan 2016, which means that 99% of all homes I inspect will not be required to have an air gap. Prior to 2016, all DW's required high loops. Now, which detail is more important to an inspector?
Note: All this info was sent to Frank by myself for his listing, so this is not an attack on someone elses post. Frank chose not to use the provided information.
Jeffrey R. Jonas
Owatonna, Minnesota
Old 2/13/18, 9:08 AM
Does a Dishwasher require a Air Gap?
Check out old forum
Old 2/13/18, 9:11 AM
I'm just concerned with current requirements.
Old 2/13/18, 9:23 AM
Roy Lewis, CMI's Avatar
Roy Lewis, CMI Roy Lewis, CMI is online now
Certified Master Inspector ®
I have never seen one around here.
From the GE dishwasher installation manual.
DRAIN REQUIREMENTS
• Follow local codes and ordinances.
• Do not exceed 10’ distance to drain.
• Do not connect drain lines from other devices to the
dishwasher drain hose.
NOTE: Air gap must be used if waste tee or disposer connection
is less than 18" above floor to prevent siphoning.
DETERMINE DRAIN METHOD
The type of drain installation depends on the following
questions.
■ Do local codes or ordinances require an air gap?
■ Is waste tee less than 18" above floor?
If the answer to either question is YES, Method 1 MUST
be used.
• If the answers are NO, either method may be used.
Method 1 – Air Gap with Waste Tee or Disposer
An air gap must be used when required by local codes and ordinances.
The air gap must be installed according to manufacturer’s instructions
Method 2 – Drain Hose Routing
When not using an air gap, the drain hose must be routed to form a high
loop of at least 32" to prevent siphoning.
http://products.geappliances.com/Mar...e=31-30588.pdf
InterNACHI Lifetime Member.
www.1stproinspection.com
roy@1stproinspection.com
Serving Gainesville Florida and surrounding areas.
Florida Certified Contractor #CRC1328001
Florida Certified Home Inspector #HI7019
Deus solus me iudicare potest
#1st Pro Inspection
Old 2/13/18, 9:35 AM
DRAIN REQUIREMENTS
questions.
be used.
I'm just looking for a simple air gap required, or high loop is okay. Don't overthink it. Keep it simple. Have you looked at the document?
Old 2/13/18, 9:38 AM
You mean the one I posted..Yes!
#1st Pro Inspection
Old 2/13/18, 9:46 AM
No.
For example :
California :Air gap required
Utah : High loop okay
Old 2/13/18, 9:55 AM
I notice that there is nothing filled in for Florida yet.
Old 2/13/18, 9:57 AM
Here is the Florida code.
It appears you can do what you want.
What do you think?
802.1.6 Domestic dishwashing machines.
Domestic dishwashing machines shall discharge indirectly through an
air gap or air break into a standpipe or waste receptor in
accordance with Section 802.2, or discharge into a
wye-branch fitting on the tailpiece of the kitchen sink or the
dishwasher connection of a food waste grinder. The waste
line of a domestic dishwashing machine discharging into a
kitchen sink tailpiece or food waste grinder shall connect to
a deck-mounted air gap or the waste line shall rise and be
securely fastened to the underside of the sink rim or counter.
#1st Pro Inspection
Old 2/13/18, 10:20 AM
Now you know why you can't find a similar list on Google. Not a simple list like you want.
Jeffrey R. Jonas
Owatonna, Minnesota
Old 2/13/18, 3:26 PM
What do you think?
Which means that the high loop is okay for Florida. That's all I wanted to know. K.I.S.S.
