Old 10/31/12, 11:07 PM
Joseph Hagarty, CMI's Avatar
Joseph Hagarty, CMI Joseph Hagarty, CMI is offline
Certified Master Inspector ®
Default Main Water Shutoff
Access could not initially be found....
(behind wall kmounted TV)
Access provided for one valve only...
not the check valve, meter or regulator....
Is there a minimum requirement for access to Plumbing isolation?
Joe Hagarty
mrdryervent@gmail.com
Cell: (484) 883-7018
Boulder, Colorado
Certified CMI Master Inspector Instructor
PA NACHI Certified Inspector # 01102902
PA Licensed Radon Inspector # 2080
PA Licensed Pesticide Applicator # 700884
Delaware Licensed Home Inspector # H4-071
Need a home inspection in Nebraska? Check out InterNACHI's listing of Nebraska certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/1/12, 8:07 AM
Barry Adair's Avatar
Location: this side of Texas dirt, another successful day
Default Re: Main Water Shutoff
disguising decorator
if the occupant remembers the location when needed it's a non-issue
i routinely find a variety of occupants crap blocking all types of system access elec panels, wh, hvac etc...
report whatever was/wasn't inspected/accessed/operated and move on
badair
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
National Association of Commercial Building Inspectors & Thermographers™ Member ID 12011-14TX
life is the random lottery of events followed by numerous narrow escapes...accept the good
Old 11/1/12, 2:31 PM
Huh??
Question is:
Is there a minimum (code) requirement for access to Plumbing isolation?
or..
is access to service / operate plumbing isolation valves provided merely as a courtesy with no code requirement...?
Joe Hagarty
Boulder, Colorado
Old 11/1/12, 11:15 PM
Charley L. Bottger's Avatar
Okla only requires to Id the location of the shut off and or absence of your milage may vary
Could of found it with the Ir Camera
http://www.oklahomathermalinfraredimaging.com/
http://www.freedomexpressinspections.com/
Master HVAC Mechanic Retired
Level III Thermographer # 8486 Infraspection Institute
CMI Certified Master Inspector
Residential/Commercial Inspections
Moisture Intrusion Expert Witness
55 years in the Trades
Okla State License # 130
580-268-3340
Old 11/2/12, 4:15 AM
Yes,
but the Homeowner was not willing to pay for that.
(We do not offer additional services for FREE)
Joe Hagarty
Boulder, Colorado
Old 11/2/12, 7:59 AM
Originally Posted by jhagarty View Post
Yes,
Do you charge extra for placing a thermometer in the oven. IR is just another tool some people understand marketing and some don't. For being on the education committee your education has a hole in it
580-268-3340
Old 11/2/12, 6:26 PM
The question seems to be lost...
I am inspecting for Buyer...
Seller hired a Contractor 5 Years ago to finish basement...
Permits were pulled and Inspections were completed...
When I asked the Homeowner where the Access to the Water Main and Sewer Cleanout were, no access and no idea where they are located...
He called the Contractor...
... suggestion is that access is not required...
so back to the original question....
are isolation valves and cleanouts required by code to be readily accessible...
or may they be concealed...?
Joe Hagarty
Boulder, Colorado
Old 11/2/12, 8:21 PM
no code required for a general home inspector
"all main utility electric, gas and water shut offs/disconnects shall be readily accessible"
many munis with locked smart meters are going to:
It is a homeowner’s responsibility to install and maintain a separate water cut-off valve, and it is highly recommended that you know where your home’s water shut-off valve is located for quick and easy access when needed. The water shut-off valve is generally located between the City’s water meter box and the front of your home, sometimes directly beside the water meter box or adjacent to the home.
It is also important to check that the water meter box and water shut-off valve are separate because the City of xyz is gradually implementing a new automated water meter reading system that requires locked water meter lids.
a provided access panel within the subject property as depicted would meet this requirement
badair
ADAIR INSPECTION
972-487-5634
TREC # 4563
Old 11/2/12, 10:17 PM
Sorry just call me Mikie
Okla does require shut off valves by state requirements on gas and water I can not image Pa not doing the same but stranger things have happed
580-268-3340
Old 11/2/12, 10:33 PM
Bob Elliott's Avatar
Around here some do not have a main shutoff in the home with access through a Buffalo key at the street.
Water meters must be requested or they estimate your bill.
Old 11/2/12, 10:34 PM
stranger things have happened
the "Dirty Dozen" have proof and memories you've been involved ;~)
badair
ADAIR INSPECTION
972-487-5634
TREC # 4563
Old 11/2/12, 10:35 PM
I have kicked the question back to the Municipal Inspector...
He issued the Permit...
He Inspected the Work....
and Signed Off on the Completion...
It is what it is now......
Joe Hagarty
Boulder, Colorado
What might cause this many cracks? bhamilton Structural Inspections 18 4/24/15 7:19 AM
Site grading and drainage wdevries Canadian Home Inspectors 5 10/6/09 10:23 PM
Need Help On Chimney Liners Nick Scibetta Exterior Inspections 13 1/11/06 9:53 PM
