Old 11/19/12, 5:21 PM
Allen L. Catterton's Avatar
Allen L. Catterton Allen L. Catterton is offline
Default Masonry support unde bathroom
Today I found a masonry / steel mesh support in a crawl space under the bathroom. The floor joist were ordinary wood joists. The concrete is bowed downward along with the mesh. I am not familiar with this type of set up. Can I get some comments? Thanks.
Masonry support unde bathroom-093-jpg   Masonry support unde bathroom-094-jpg
Allen L. Catterton, CMI
Catterton Home Inspections
http://www.cattertonhomeinspections.com
Need a home inspection in Vermont? Check out InterNACHI's listing of Vermont certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/19/12, 6:59 PM
James E. Braun, CMI's Avatar
Certified Master Inspector
Default Re: Masonry support unde bathroom
Does the top of the floor look okay? If so they probably laid over it with heavy sheathing, which should be okay.
Braun Inspection Consultants
Serving Jefferson City, Columbia, Sedalia, Fulton and Lake of the Ozarks
Old 11/19/12, 7:50 PM
Kenneth R. Brittain's Avatar
Kenneth R. Brittain Kenneth R. Brittain is online now
Older home with Tile floor?
Old 11/19/12, 8:08 PM
The sub floor is covered with vinyl flooring. It is stable and solid to walk on. I guess my initial concern was with the apparent bowing of the cement but I guess it likely looked like that soon afeter it was poured in 1959. Don't see very many like that here. Thanks for your reply.
Old 11/20/12, 8:43 AM
Jeffrey R. Pope, CMI's Avatar
Jeffrey R. Pope, CMI Jeffrey R. Pope, CMI is offline
Certified Master Inspector ®
I'm surprised to hear of a crawlspace in FL
This is common in older homes beneath tile floors. It's also the same method used for heart-extensions in masonry fireplace systems where the home is on a raised foundation.
The weight of the wet concrete created the "bowing" you were referring to. It cured in that position rather than becoming distorted over time.
Jeff Pope
JPI Home Inspection Service
(661) 212-0738
Los Angeles, Santa Clarita & Antelope Valley CA
Old 11/20/12, 9:16 AM
Joe Funderburk, CMI's Avatar
Joe Funderburk, CMI Joe Funderburk, CMI is online now
As others stated, it almost certainly had tile at one time. At least it was designed for tile and they changed their mind perhaps after money got tight.
Theodore Roosevelt
Joe Funderburk, CBO, CMI
Angie's List Super Award Winner 2017, 2016, 2015, 2014, 2013, 2012, 2011, 2010.
Ph: 704-351-1776
www.aohomeinspection.com
Support for Exterior Masonry Chimney bhubbell Exterior Inspections 3 2/9/08 5:40 PM
Max load allowed on 2x2 ledger bking Structural Inspections 4 12/23/07 2:05 PM
Basement Bathroom Venting Question Sean M. Jeric Plumbing Inspections 4 3/20/07 11:56 PM
Online Code Check- Reference pabernathy Electrical Inspections 31 11/9/06 3:39 PM
