Old 12/11/12, 1:03 PM
Juan C. Jimenez Juan C. Jimenez is offline
Default This is ok right?
The home owner was very proud of this.
Sump pump in a bucket in the ground to accommodate the dehumidifier. Check valves in wrong place and connected below the drain line. Did I miss any thing? This is being submitted next month Marcel
This is ok right?-winslow-200-jpg   This is ok right?-winslow-199-jpg   This is ok right?-winslow-198-jpg   This is ok right?-winslow-181-jpg   This is ok right?-winslow-182-jpg
Juan Jimenez
A House on a Rock Home Inspections LLC
God. Family. Home.
804-269-4321
Richmond Home Inspector
Richmond Chimney Sweep
Richmond Radon Testing
Need a home inspection in Oregon? Check out InterNACHI's listing of Oregon certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/11/12, 1:22 PM
Charley L. Bottger's Avatar
Default Re: This is ok right?
Your PIC's are hard to understand. I see a pump in a bucket that has holes that appears to allow water into the bucket and a pump discharging into a sanitary Tee with no check in the discharge line. Its not standard to discharge into a Tee I see no other drain line into the bucket I'm looking at ground water where is the humidifier drain connected at.
I have more questions than answers
http://www.oklahomathermalinfraredimaging.com/
http://www.freedomexpressinspections.com/
Master HVAC Mechanic Retired
Level III Thermographer # 8486 Infraspection Institute
CMI Certified Master Inspector
Residential/Commercial Inspections
Moisture Intrusion Expert Witness
Okla State License # 130
580-268-3340
Old 12/11/12, 1:39 PM
The dehumidifier didn't drain anywhere. It just soaked the ground. The home owner put a bucket in the ground to accommodate this. He installed check valves at some random places in the gravity drains instead of on the discharge line. He connected the discharge line below the gravity drain with a sanitary tee instead of above it with a wye. LOL I was kidding with the title...
Juan Jimenez
God. Family. Home.
804-269-4321
Old 12/11/12, 1:40 PM
I think the home owner tried to encapsulate the crawlspace himself
Juan Jimenez
God. Family. Home.
804-269-4321
Old 12/11/12, 1:46 PM
Looks like a misguided POS to me
580-268-3340
