Old 12/22/12, 5:08 PM
Bill Smith's Avatar
Bill Smith Bill Smith is offline
Please Note: bsmith is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Pex near vent connector
I know that normally pex shouldn't be installed within 6" of a single walled vent connector. This oil-fired water heater (and boiler) was power vented, which to my way of thinking, reduces the vent temperature considerably. Do power vented appliances have different pex/vent distance requirements? BTW - The AHJ approved the installation.
Pex near vent connector-img_6136-jpg
Need a home inspection in Alabama? Check out InterNACHI's listing of Alabama certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/22/12, 5:17 PM
Stephen W. Stanczyk's Avatar
Stephen W. Stanczyk Stephen W. Stanczyk is online now
Default Re: Pex near vent connector
Almost all of the power vent appliances I have seen use PVC vent pipes and it does look like this one is as well. I don't see an issue.
Stephen Stanczyk
Pierce County -Thurston County - King County - Kitsap County
Old 12/22/12, 5:23 PM
Bill Smith's Avatar
The vent connector is single walled metal. I was concerned about the pex being too close to it.
Old 1/25/13, 9:55 PM
John dematteo John dematteo is offline
Please Note: John dematteo is a non-member guest and is in no way affiliated with InterNACHI or its members.
you require 6 inch clearance
help with this vent connector mnicholet Inspecting HVAC Systems 2 6/14/10 8:12 PM
Vent connector mnicholet Plumbing Inspections 5 8/23/09 12:20 PM
Single wall vent connector mnicholet Inspecting HVAC Systems 3 3/31/09 10:26 PM
Gas and oil hot water tank and Boiler Share Vents hvanderbeek Miscellaneous Discussion for Inspectors 8 1/25/07 6:22 PM
