Old 2/14/12, 5:15 PM
John Gromkoski's Avatar
John Gromkoski John Gromkoski is offline
Please Note: jgromkoski is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default T&P Pipe and Gas Drip Leg
Has anything changed recently with respect to the material for a T & P relief valve extension pipe? I have come across a few water heaters with Schedule 40 PVC being used on a 4 year old house, and new water heater installation by Sears. Did I miss the memo?
I have also seen no drip leg provided at the gas line to the water heater and furnaces, just an elbow turned into the gas valves. Did I miss something there too?
Need a home inspection in North Carolina? Check out InterNACHI's listing of North Carolina certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/14/12, 5:34 PM
Jeffrey R. Pope, CMI's Avatar
Jeffrey R. Pope, CMI Jeffrey R. Pope, CMI is offline
Certified Master Inspector ®
Default Re: T&P Pipe and Gas Drip Leg
Nothing has changed. PVC is not allowed for TPR discharge. Sediment traps are required by some codes and most manufacturers, but not all.
IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE «
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 2/14/12, 5:44 PM
Whew! Thought I missed something. Thanks Jeff.
Old 2/14/12, 6:19 PM
James F. McKee's Avatar
with the popularity of the big box stores and their "installation Kits"...you just never know what You are going to find...
Jim McKee
Amherst, Ohio
440 225 8688
www.amhersthomeinspector.com
Old 2/14/12, 6:30 PM
Very much agreed James. That's why we do what we do.
