Old 11/27/12, 10:00 AM
Jeffrey A. Prince Jeffrey A. Prince is offline
Default Pipe Insulation
Does anybody know what this pipe wrap is made of? Sticky like tar. House was built in late 50's. Does not look like common asbestos insulation to me. Just checking to see what you guys think
Pipe Insulation-100_7372-jpg   Pipe Insulation-100_7377-jpg
Safe At Home Inspections,Inc.
Home Inspections performed in Darien, Downers Grove, Lisle, Westmont, Woodridge, Naperville, Aurora, and all surrounding areas in Greater Chicagoland.
630-437-1572
Need a home inspection in New Jersey? Check out InterNACHI's listing of New Jersey certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/27/12, 10:10 AM
Roy D. Cooke, Sr's Avatar
Default Re: Pipe Insulation
I see nothing to make me think it is asbestos..
Old 11/27/12, 10:42 AM
I feel the same I just like too double check thanks for your reply
630-437-1572
Old 11/27/12, 11:11 AM
David A. Andersen, TN HI# 40's Avatar
David A. Andersen, TN HI# 40 David A. Andersen, TN HI# 40 is offline
If it were made of asbestos it wouldn't matter, nothing is going to "escape" that sticky mess!
That is an older pipe insulation primarily used in Refrigeration pipe applications (can't remember the name of it off the top of my head, maybe that "Old Fart" Charley will know).
Clarksville - Nashville Home Inspector Lic#40 (Retired)
BPI# 5015804
Old 11/27/12, 11:16 AM
James F. McKee's Avatar
Jim McKee
Lorain, Ohio
440 225 8688
www.classicinspector.com
Old 11/27/12, 10:51 PM
Charley L. Bottger's Avatar
Really looks like plumbing Oakum that has been impregnated with tar goop These kids have not seen much
http://www.oklahomathermalinfraredimaging.com/
http://www.freedomexpressinspections.com/
Master HVAC Mechanic Retired
Level III Thermographer # 8486 Infraspection Institute
CMI Certified Master Inspector
Residential/Commercial Inspections
Moisture Intrusion Expert Witness
55 years in the Trades
Okla State License # 130
580-268-3340
Old 11/27/12, 10:56 PM
There is also a bad connector joint on the fixture wire that needs to be repaired by a Qualified person
Old 11/27/12, 11:03 PM
Larry Kage, CMI's Avatar
Larry Kage, CMI Larry Kage, CMI is offline
Certified Master Inspector ®
...not to mention the lamp cord usage.
Awards Committee Officer
SUBMIT YOUR AWARD NOMINATIONS HERE:
http://co.nachi.org/inachiawards/
Larry Kage, CMI Lifetime Member
State Licensed Builder since 1973
InterNACHI Lifetime Member
~retired~
The above post represents my personal opinion.
Old 11/28/12, 5:58 AM
ldapkus1's Avatar
ldapkus1 ldapkus1 is offline
Please Note: ldapkus1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Asbestos rope.
Identify ABS defective pipe mcyr Plumbing Inspections 11 11/18/15 10:42 PM
Asbestos Pipe Insulation Question David Duchenne General Inspection Discussion 15 1/19/12 11:22 AM
Pellet stove help chellickson General Inspection Discussion 23 8/19/10 1:23 AM
Vermiculite Insulation Inspectors in Coeur d’Alene, ID 83815 rspriggs Ancillary Inspection Services 3 1/10/09 8:43 PM
New Old Insulation rcooke Canadian Home Inspectors 1 12/13/06 5:25 PM
