Old 8/22/12, 12:03 AM
Sam Morris, 341 CMI Sam Morris, 341 CMI is offline
Default Pipe for laundry washer drain line
This drain pipe is located in the basement behind the washing machine. How does this work when the water has to travel UP, over and down into the sump pump. Does this put extra strain on the washing machine?
Pipe for laundry washer drain line-dsc04227-jpg   Pipe for laundry washer drain line-dsc04233-jpg   Pipe for laundry washer drain line-dsc04226-jpg
Need a home inspection in Pennsylvania? Check out InterNACHI's listing of Pennsylvania certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 8/22/12, 12:09 AM
Joseph Hagarty, CMI's Avatar
Joseph Hagarty, CMI Joseph Hagarty, CMI is offline
Certified Master Inspector ®
Default Re: Pipe for laundry washer drain line
If you are suggesting that the Laundry Washer is discharging to an open sump in the Basement floor.....
It is wrong / defective and in need of professional repair.
Joe Hagarty
mrdryervent@gmail.com
Cell: (484) 883-7018
Boulder, Colorado
Certified CMI Master Inspector Instructor
PA NACHI Certified Inspector # 01102902
PA Licensed Radon Inspector # 2080
PA Licensed Pesticide Applicator # 700884
Delaware Licensed Home Inspector # H4-071
Old 8/22/12, 12:13 AM
Yes I agree, but this house was built in 1940 and the washing machine is lower than the sewer drain line.
Old 8/22/12, 12:15 AM
Bob Elliott's Avatar
InterNACHI Applicant
I am not getting the whole story in those pictures but ,what Joe said.
Old 8/22/12, 12:16 AM
The Laundry Washer has the ability to pump UP to the sanitary drain.
Discharge of gray water to an open floor sump is not permitted (in this area) due to health and soil contamination concerns.
You mileage and area may vary.....
Joe Hagarty
Boulder, Colorado
Old 8/22/12, 12:21 AM
OK.. I get it no sump pumps discharging gray water into back yard.
Old 8/22/12, 12:23 AM
Yeah,Joe is thinking it should be a ejector pump.
Assuming this sump goes to the exterior.It has a backup so it is a good guess it does.
Old 8/22/12, 12:26 AM
What does a ejector pump do, is it completely enclosed?
Old 8/22/12, 12:27 AM
Yes an ejector pump is designed to empty into the main sewer with a closed top as they are often used for a toilet.http://activerain.com/blogsview/2665...kles-in-water-
Old 8/22/12, 12:32 AM
Thank You
Old 8/22/12, 12:40 AM
N.P ,ask away as most of us are here to help and be helped.
NACHI helped me greatly at the beginning which keeps me here.
Old 8/22/12, 12:50 AM
Stephen W. Stanczyk's Avatar
Stephen W. Stanczyk Stephen W. Stanczyk is online now
I have a rental with a sewage basin that the laundry sink / washing machine empty into through a drain line from the sink into the concrete floor and over about 3 feet into the basin. It is not a sump, it is a sealed basin in the floor with a pump up to one of the waste lines. The difference between a sump and a basin is a sump is open to the ground where a basin is sealed from the ground. The pedestal pump has a check valve so nothing can flow back into the basin. Very common with the few and far between basements in my area.
Stephen Stanczyk
Pierce County -Thurston County - King County - Kitsap County
with over 10 years...
I still learn from NACHI everyday.....
Joe Hagarty
Boulder, Colorado
Old 8/22/12, 12:56 AM
http://www.grainger.com/Grainger/ZOE...&cm_vc=IDPBBZ2
Joe Hagarty
Boulder, Colorado
Old 8/22/12, 1:41 AM
Christopher Currins, CMI Christopher Currins, CMI is offline
I've had two similar within the last week, except they weren't connected to waste line, or sealed. Pumps in basins with no drain tile or any other inlet pipe, with the discharge pipe at exterior wall. Both pumps were plugged into receptacle.
Neither had an inlet pipe. Both owners said their basements are always dry and the "sump pump" never comes on.
When I informed them there was no perimeter drain tile system connected to the basin and the only way to activate the pump would require them to fill the basin themselves they were a little shocked.
They thought they had a foundation drain tile system.
Pipe for laundry washer drain line-p1013017-jpg   Pipe for laundry washer drain line-p1012819-jpg
Help - Polybutylene Pipes Rick G Plumbing Inspections 45 6/26/13 5:21 PM
Washer machine drain pan jjimenez Plumbing Inspections 11 7/15/12 5:21 PM
Code - Backup condensate drain line being plumbed to exterior ralexander1 Inspecting HVAC Systems 2 6/2/11 9:00 PM
