Old 7/24/12, 10:54 AM
Richard W. Washington, TREC#7238's Avatar
Richard W. Washington, TREC#7238 Richard W. Washington, TREC#7238 is offline
Default pipes under sink?
Yesterdays new construction inspection. I found these pipes under one of the master bath sinks. had never seen this before. There was no water softener. The home is on city water supply.
pipes under sink?-dsc07411-jpg
Richard W. Washington, owner
RW Home Inspections, Inc.
www.RWHOMEINSPECTIONS.com
Texas Real Estate Commission (TREC)
Professional Inspector License #7238
Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter
InterNACHI member since 2004
Based in Katy, serving Houston and all surrounding communities
Need a home inspection in South Dakota? Check out InterNACHI's listing of South Dakota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/24/12, 10:55 AM
Default Re: pipes under sink?
to clarify. i am not referring to the black primary condensate line.
Old 7/24/12, 10:57 AM
Jeffrey R. Jonas's Avatar
InterNACHI Applicant
Tempering valve for the toilet?
Jeffrey R. Jonas
Owatonna, Minnesota
Old 7/24/12, 11:28 AM
Michael Larson's Avatar
Michael Larson Michael Larson is online now
That's my guess to prevent the toilet from sweating.
As a Professional Home Inspector, I support the privacy of my clients.
You own your private information. I won't sell or give away yours, others do
www.InspectraPro.com
www.MinnesotaHomeInspector.biz
Michael Larson
Hudson, WI
Call me
Old 7/24/12, 1:38 PM
Muhammad R. Qureshi's Avatar
Muhammad R. Qureshi Muhammad R. Qureshi is offline
Please Note: mqureshi is a non-member guest and is in no way affiliated with InterNACHI or its members.
Is that the same as mixing valve?
Old 7/24/12, 2:07 PM
Stephen W. Stanczyk's Avatar
Stephen W. Stanczyk Stephen W. Stanczyk is online now
Site specific temperature mixing valve for the tub / shower. Just started finding these on new construction and in the weirdest places.
You can also use these when you want to keep the old 3 handle style faucets in a tub / shower for aesthetic purposes.
Stephen Stanczyk
Pierce County -Thurston County - King County - Kitsap County
Old 7/24/12, 2:44 PM
Bob Elliott's Avatar
Keeps you from adjusting your own temp in the shower?
That seems stupid.
Old 7/24/12, 2:57 PM
In my area (GTA), we find mixing valves in the basement by the water heater and not for each fixture individually.
As far as I know, water is kept at 140F in the WH tank to keep bacteria growth to a minimum and to slow down the corrosion process inside.
The mixing value reduces the temperature from 140F to a more reasonable temperature which reduces the risk of hot water scalding.
...unless I am mixing this mixing value with something else
Old 7/24/12, 4:11 PM
David C. Macy, CMI's Avatar
David C. Macy, CMI David C. Macy, CMI is online now
Certified Master Inspector
I am curious if the house has a tank less or conventional water heater?
http://www.hshinspections.net/
Performing Home Inspections in Cleveland, Strongsville, Brecksville, Broadview Heights, North Royalton, Parma and surrounding areas.
http://storage.pardot.com/130671/272...Color125px.png
Old 7/24/12, 5:32 PM
OK ,that makes sense.
Old 7/24/12, 7:15 PM
It takes the place of a built in temperature regulator found in most new faucets. When I went to put in a new 3 handle H-C-S during a full rehab, the AHJ would not allow it without a "listed antiscald / pressure balance valve" which the 3 faucet did not meet. Thus the balancing valve under the sink next to the tub.
Stephen Stanczyk
Old 7/24/12, 8:08 PM
John Overholser's Avatar
John Overholser John Overholser is offline
Was there a tub next to the sink?
http://www.ttbservices.com
MD License# 31233
WV HI4572294-0717
Infrared Certified
Mold Certified
Water Certified
Lead Risk Assessor
Old 7/25/12, 8:54 AM
Barry Adair's Avatar
Location: this side of Texas dirt, another successful day
comparison or code reference
water tempering valves
http://media.wattswater.com/F-ProdSelectionGuide.pdf
Can
http://www.cashacme.com/_images/pdf_...CodeUpdate.pdf
badair
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
National Association of Commercial Building Inspectors & Thermographers™ Member ID 12011-14TX
life is the random lottery of events followed by numerous narrow escapes...accept the good
Old 7/25/12, 12:00 PM
KEVIN WOOD, CMI KEVIN WOOD, CMI is offline
Banned
Please Note: kwood is a non-member guest and is in no way affiliated with InterNACHI or its members.
Barry we use Union Gas here and this is a great slide show.
http://www.uniongas.com/residential/.../whInstall.htm
Notice the mixing valve in the middle.
Faulty pipes cause headaches for homeowners rcooke Canadian Home Inspectors 4 4/29/13 11:12 PM
Cast iron drains jfrederick Plumbing Inspections 20 1/20/12 12:41 AM
Flushing pipes with acid? Alexandra Baxter Plumbing Inspections 9 12/6/08 6:49 PM
Sink Clog dirtydishes Plumbing Inspections 26 8/27/06 4:48 PM
