Old 7/24/12, 9:54 AM
Richard W. Washington, TREC#7238's Avatar
Richard W. Washington, TREC#7238 Richard W. Washington, TREC#7238 is offline
Default pipes under sink?
Yesterdays new construction inspection. I found these pipes under one of the master bath sinks. had never seen this before. There was no water softener. The home is on city water supply.
Richard W. Washington, owner
RW Home Inspections, Inc.
www.RWHOMEINSPECTIONS.com
Texas Real Estate Commission (TREC)
Professional Inspector License #7238
Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter
InterNACHI member since 2004
Based in Katy, serving Houston and all surrounding communities
Need a home inspection in South Dakota? Check out InterNACHI's listing of South Dakota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/24/12, 9:55 AM
Default Re: pipes under sink?
to clarify. i am not referring to the black primary condensate line.
Old 7/24/12, 9:57 AM
Jeffrey R. Jonas's Avatar
Tempering valve for the toilet?
Jeffrey R. Jonas
Owatonna, Minnesota
Old 7/24/12, 10:28 AM
Michael Larson's Avatar
Michael Larson Michael Larson is online now
That's my guess to prevent the toilet from sweating.
As a Professional Home Inspector, I support the privacy of my clients.
www.InspectraPro.com
www.MinnesotaHomeInspector.biz
Michael Larson
Hudson, WI
Call me
Old 7/24/12, 12:38 PM
Muhammad R. Qureshi's Avatar
Muhammad R. Qureshi Muhammad R. Qureshi is offline
Please Note: mqureshi is a non-member guest and is in no way affiliated with InterNACHI or its members.
Is that the same as mixing valve?
Old 7/24/12, 1:07 PM
Stephen W. Stanczyk's Avatar
Stephen W. Stanczyk Stephen W. Stanczyk is online now
Site specific temperature mixing valve for the tub / shower. Just started finding these on new construction and in the weirdest places.
You can also use these when you want to keep the old 3 handle style faucets in a tub / shower for aesthetic purposes.
Stephen Stanczyk
Pierce County -Thurston County - King County - Kitsap County
Old 7/24/12, 1:44 PM
Bob Elliott's Avatar
Keeps you from adjusting your own temp in the shower?
That seems stupid.
Old 7/24/12, 1:57 PM
In my area (GTA), we find mixing valves in the basement by the water heater and not for each fixture individually.
As far as I know, water is kept at 140F in the WH tank to keep bacteria growth to a minimum and to slow down the corrosion process inside.
The mixing value reduces the temperature from 140F to a more reasonable temperature which reduces the risk of hot water scalding.
...unless I am mixing this mixing value with something else
Old 7/24/12, 3:11 PM
David C. Macy, CMI's Avatar
David C. Macy, CMI David C. Macy, CMI is online now
Certified Master Inspector
I am curious if the house has a tank less or conventional water heater?
http://www.hshinspections.net/
Performing Home Inspections in Cleveland, Strongsville, Brecksville, Broadview Heights, North Royalton, Parma and surrounding areas.
http://storage.pardot.com/130671/272...Color125px.png
Old 7/24/12, 4:32 PM
OK ,that makes sense.
Old 7/24/12, 6:15 PM
It takes the place of a built in temperature regulator found in most new faucets. When I went to put in a new 3 handle H-C-S during a full rehab, the AHJ would not allow it without a "listed antiscald / pressure balance valve" which the 3 faucet did not meet. Thus the balancing valve under the sink next to the tub.
Stephen Stanczyk
Old 7/24/12, 7:08 PM
John Overholser's Avatar
John Overholser John Overholser is offline
Was there a tub next to the sink?
http://www.ttbservices.com
MD License# 31233
WV HI4572294-0717
Infrared Certified
Mold Certified
Water Certified
Lead Risk Assessor
Old 7/25/12, 7:54 AM
Barry Adair's Avatar
Location: this side of Texas dirt, another successful day
comparison or code reference
water tempering valves
http://media.wattswater.com/F-ProdSelectionGuide.pdf
Can
http://www.cashacme.com/_images/pdf_...CodeUpdate.pdf
badair
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
National Association of Commercial Building Inspectors & Thermographers™ Member ID 12011-14TX
life is the random lottery of events followed by numerous narrow escapes...accept the good
Old 7/25/12, 11:00 AM
KEVIN WOOD, CMI KEVIN WOOD, CMI is offline
Banned
Please Note: kwood is a non-member guest and is in no way affiliated with InterNACHI or its members.
Barry we use Union Gas here and this is a great slide show.
http://www.uniongas.com/residential/.../whInstall.htm
Notice the mixing valve in the middle.
Faulty pipes cause headaches for homeowners rcooke Canadian Home Inspectors 4 4/29/13 10:12 PM
Cast iron drains jfrederick Plumbing Inspections 20 1/19/12 11:41 PM
Flushing pipes with acid? Alexandra Baxter Plumbing Inspections 9 12/6/08 5:49 PM
Sink Clog dirtydishes Plumbing Inspections 26 8/27/06 3:48 PM
