Old 1/9/16, 4:54 AM
Steven Anzelc, CPI CCI Steven Anzelc, CPI CCI is offline
Default Plumbing vent in attic
Greetings, This is the first time I have seen open plumbing vents in attic and btw no roof exhaust vents either It was constructed 2014.
My training tells me this would not be ok because of moisture, odors, unhealthy gas etc not to mention ability for insulation and mice to go down.
It is in Missouri, which I think they may allow AAVs on a limited basis but I don't see how this is ok at all.
I am also confused about the two big pipes in the background in the inaccessible area of the attic.
Please help. Thanks!!!!!!
Warm regards
Steve
Plumbing vent in attic-154-jpg   Plumbing vent in attic-159-jpg   Plumbing vent in attic-150-jpg
Need a home inspection in Washington? Check out InterNACHI's listing of Washington certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/9/16, 8:18 AM
Roy D. Cooke, Sr's Avatar
Default Re: Plumbing vent in attic
Wrong all vent's must go to the out side .
Good catch make sure you write this up so you do not have to pay for the fix in the future.
I have seen where an open vent has caused the roof sheathing to decay.
WE have it colder then you and the roof was wet in the cooler weather .
Is there Gable vents and soffit vents If not yes they need to fix attic ventilation .
I also think they need more Attic insulation
Old 1/9/16, 11:49 AM
Thanks Roy.
What do you think the two larger PVC at angles are? More vent stacks, and if so, why at angles?
They do have one small gable vent and a bunch of soffit vents on the hip portions but no "turtle vents" or other roof exhaust. I was going to put the plumbing vent issue on the RED but recommend increase in roof ventilation on the non MAJOR to prevent rafter bowing in the future.
Regarding insulation, it is 6" average.
Old 1/9/16, 5:39 PM
Originally Posted by sanzelc View Post
Thanks Roy.
Two PVC pipes on angle No idea why please have a plumber Check them and repair them if needed .
Old 1/9/16, 7:16 PM
Wayne B. Wilson, TN 439's Avatar
Wayne B. Wilson, TN 439 Wayne B. Wilson, TN 439 is offline
Yep wrong , must go to the outside
Wayne Wilson CMI
East TN Home Inspections LLC
865-256-1490
https://www.myhomeinspection.net/
Old 1/9/16, 7:20 PM
Shawn D. Staggs, CPI's Avatar
Shawn D. Staggs, CPI Shawn D. Staggs, CPI is offline
Community Guest
Yuppers total fail!! Great catch
Anchor Bay Inspections
Florida Licensed Home Inspector HI8446
941-676-2375
Serving Sarasota, Bradenton, Longboat Key, Anna Marie Island
Holmes Beach, Palmetto, Venice, Port Charlotte and Punta Gorda
Home Inspection - Wind Mitigation - Four Point Inspections
Old 1/9/16, 7:25 PM
Bradley K. Toye, CMI's Avatar
Bradley K. Toye, CMI Bradley K. Toye, CMI is online now
Certified Master Inspector
Must have ran out of pipe that day. That tee fitting was even primed on top. Just plain wrong, and have never seen that before.
Brad K Toye
ITC/FLIR Level I Building Investigation Thermographer
FL Certified Building Contractor CBC034303
FL Certified Home Inspector HI 391
FL Certified Mold Assessor MRSA 589
727-403-5029
Lecsi2@gmail.com
www.LeadingEdgeInspectionServices.com
Old 1/9/16, 10:03 PM
Christopher M. Deakins's Avatar
Christopher M. Deakins Christopher M. Deakins is offline
the house gets quickly put under roof during construction, then plumbers plumb up to the attic and have final connection point all prepped and primed for that last pipe to attach and extend through the roof, but communication fails between roofer and plumber and there it sits.
the other pipes are probably vents too, its very common to have multiple vents enter the attic and converge into one stack through the roof, or have multiple stacks through the roof, depending on how far apart they are from each other and which is more feasible.
if there are soffit vents then there should be baffles to keep blown insulation from clogging the eves, no baffles visible in pictures
Christopher Deakins
Distribution Coordinator - Duke Energy Corporation
Industrial Electrician
http://www.deakinshomeinspections.com/
Old 1/12/16, 12:13 PM
Justin Shields's Avatar
Justin Shields Justin Shields is offline
Yeah, those pipes sitting there at an angle may possibly not be attached to anything at all. Did you try to move them?
612 Home Inspections, LLC
Serving Minneapolis, St. Paul, Bloomington, Maple Grove, Plymouth, Minnetonka and the entire Twin Cities metro.
Justin Shields, CPI
Phone: 612.590.1141
Email: 612homeinspections@gmail.com
http://www.612homeinspections.com
http://www.homeinspectioninminneapolis.com
Old 1/13/16, 10:43 PM
Michael Bitterman, CMI HI7792's Avatar
Michael Bitterman, CMI HI7792 Michael Bitterman, CMI HI7792 is online now
They are all probably vents, what has happened is the plumbers ran the vents to the attic after the sheathing was on, which is normal. Then along came the roofers who should have cut holes in the sheathing, put on boots, flashing, what have you, then shingle the roof.....Bet you can guess what the roofers forgot to do! I have seen this before.
Mike Bitterman CMI
SNS Home Inspections LLC
Serving all of Central Florida
http://www.snsinspections.com
Old 9/19/18, 2:28 PM
Thomas G. Edwards Thomas G. Edwards is offline
and i just saw it done yesterday and thought I was the 1st too see it done.
Old 9/19/18, 2:39 PM
Here is an unvented vent .
Plumbing vent in attic-img_3757-jpg
