Old 4/1/13, 4:57 PM
Stewart Mussolum Stewart Mussolum is offline
Certified Master Inspector
Default pressure tank system
OK. I see the the pressure tank, 2 pressure switches, gauge, water filters and softner and uv light.
What are the 2 pipes going below grade?
Any other observations or comments are welcome.
pressure tank system-brouwers-line-47115-061-jpg   pressure tank system-brouwers-line-47115-064-jpg   pressure tank system-brouwers-line-47115-062-jpg
ASSOCIATED REAL ESTATE INSPECTIONS INC.
HOME AND COMMERCIAL PROPERTY INSPECTORS
" WE DON'T CARE IF YOU BUY THE PROPERTY - WE DO CARE ABOUT INSPECTING IT RIGHT THE FIRST TIME"
p - 519 494 3986 f - 519 645 3986
stew@arei.ca
http://www.arei.ca
Servicing London & All Of Ontario
Need a home inspection in Hawaii? Check out InterNACHI's listing of Hawaii certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/1/13, 8:05 PM
Marcel Gratton, CMI's Avatar
Marcel Gratton, CMI Marcel Gratton, CMI is offline
Certified Master Inspector ®
Default Re: pressure tank system
Outbuildings perhaps, you tell us.
On The Level Inspection
Gatineau, Québec
Old 4/1/13, 8:26 PM
Cameron Anderson's Avatar
Cameron Anderson Cameron Anderson is offline
How old is the house and are there water sources at any outbuildings?
One could be a faucet run out to a building or garden, or possibly an old well source.
Cameron Anderson
Integrity Home Inspection
Truth. In Real Estate.
Since 2004
Bachelor of Architecture, U of I, Urbana IL
Illinois Licensed Inspector
www.homeinspectionpeoria.com
Old 4/1/13, 10:22 PM
There is a shed with pool equipment and the garage has a wash down station that appears to be fed from below grade so that explains the below grade piping. Thanks.
Still curious about some the other piping and valves. The seller has no idea. I have recommended that my buyer client get an evaluation from a well contractor.
Thanks
stew@arei.ca
http://www.arei.ca
Old 4/2/13, 3:03 AM
Good idea, especially if your buyer is unfamiliar with well operation and maintenance.
Cameron Anderson
Since 2004
Pressure tank on public water dokeefe Plumbing Inspections 2 1/6/12 9:15 AM
PLEASE HELP! Need to change the SOPs, per NEMA ktarasenko Electrical Inspections 76 4/19/10 8:15 PM
Where's My Water Pressure?? David Smfh Plumbing Inspections 4 12/23/09 8:30 PM
Make $50.00 More Profit per Inspection with Septic Tanks ebeahm1 Ancillary Inspection Services 6 8/20/09 1:38 PM
