Old 10/9/06, 5:24 PM
Ronald P. Feiler Ronald P. Feiler is offline
Default Propane and natural gas lines.
Ok. who is the pro out there??? What materials can and can't be used for gas lines? What fittings and connectors can be used. What is the best source of info on the subject??
Old 10/9/06, 5:44 PM
Default Re: Propane and natural gas lines.
It depends on where you are. Contact your local authority...it all differs from one jurisdiction to another.
Old 10/9/06, 5:45 PM
Michael Larson's Avatar
Michael Larson Michael Larson is online now
I prefer black iron pipe myself but often see copper with flare fittings. Also see CSST which requires special tools to apply fittings or factory pre-assembled lengths used for appliance connection.
Copper is not permitted in some jurisdictions because of certain chemicals in local gas supplies.
In all cases you should check with the local fuel supplier and AHJ for gas appliance installations.
Old 10/9/06, 5:47 PM
Larry Kage, CMI Larry Kage, CMI is offline
Certified Master Inspector ®
What is acceptable can be different in diffent areas (states, counties, townships, etc.)
I'd check with your local AHJ or gas utility companies.
Awards Committee Member
SUBMIT YOUR AWARD NOMINATIONS HERE:
http://co.nachi.org/inachiawards/
Larry Kage, CMI 2004-2017
State Licensed Builder since 1973
InterNACHI Lifetime Member
~retired~
The above post represents my personal opinion.
Old 10/9/06, 6:12 PM
Roy D. Cooke, Sr's Avatar
Lots of information it is 121 pages but much information .
http://www.questargas.com/brochures/59060_401.pdf
Roy Cooke
Old 10/10/06, 12:27 AM
Brian E. Kelly's Avatar
http://www.nfpa.org/aboutthecodes/Ab...ookie%5Ftest=1
or Call your local gas company
Old 10/14/06, 4:42 AM
Steven R. Medina's Avatar
Steven R. Medina Steven R. Medina is offline
I saw this on a house I inspected Wensday. I know some jurisdictions don't allow cooper tubing for natural gas but what about supporting the line itself.How would you guys write this up? The looped line is the gas line going up thru the floor connected to the stove.
Propane and natural gas lines.-i55-jpg
Old 10/17/06, 3:08 PM
Not seeing the rest of the line, it's tough to say. But something like The line does not appear to be properly secured or The line may be subject to damage. Don't forget when in doubt recommend a second opinion from a qualified gas guy. The loop itself is not a concern.
Old 10/19/06, 8:26 PM
Thanks Ron, thats pretty much how I wrote it up. That the gas line was not secured properly. I'm a newbie still trying to learn the best way phrase things.
Furnace Question ccrooker Canadian Home Inspectors 13 10/27/06 8:21 AM
TSSA Gas natural draft boiler notice rwand1 Canadian Home Inspectors 1 9/13/06 12:37 AM
Another question for Y'all twheeler Inspecting HVAC Systems 23 1/23/06 10:32 PM
