Old 5/6/12, 10:26 AM
Roy D. Cooke, Sr's Avatar
Default Recall notice???
I have a GE power vent water heater .
It quit working Friday AM. Went down and could not get a response from the controller .
Unplugged it waited 2 minutes and Powered it up went through the set up and it worked for about 5 minutes then quit.
Did it again only waited 10 minutes and again it started and worked for 5 minutes . 30 min tried it again and it has worked OK since .
I went to a supplier with the white Control he said he thought there had been a recall last year on this .
I have not been able to find this on the net have you any info ideas on this .
Tank Serial #1108903250 mod GG50s06RVK item 984903205
Purchased Jan 2009 . I will be contacting Rheem on Monday
Any thoughts or ideas appreciated ... Roy
Recall notice???-100_1405-jpg   Recall notice???-100_1409-jpg
Need a home inspection in Michigan? Check out InterNACHI's listing of Michigan certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/6/12, 10:59 AM
Default Re: Recall notice???
There was a gas valve recall. That's all I could find.
Old 5/7/12, 1:34 PM
Jeffrey R. Jonas's Avatar
InterNACHI Applicant
Who cares about a recall. It is only three years old... get your warranty honored!
Jeffrey R. Jonas
Owatonna, Minnesota
Old 5/14/12, 10:19 AM
I called Rudd and their service ladies are the best .
They speak clear and good volume ,
Went through the system with me and decided what was needed sent me the part via Purlator simple install took about 15 minutes and system has worked great since then .
Sent Spare clips screws and even a tork screw driver .
No charge .
They only Guarantee parts after 3 years no service .
Recall notice???-100_1470-jpg
Recall Notice mcyr Miscellaneous Discussion for Inspectors 3 2/22/12 9:25 PM
Recall Notice jjonas Inspecting HVAC Systems 0 3/12/08 7:20 PM
Recall Notice jjonas Electrical Inspections 0 3/12/08 7:19 PM
Recall Notice - CPSC Notice pabernathy Electrical Inspections 1 1/25/07 8:34 PM
