Old 12/6/12, 4:33 PM
Richard W. Washington, TREC#7238's Avatar
Richard W. Washington, TREC#7238 Richard W. Washington, TREC#7238 is offline
Default Are the H/C reversed?
took the pic from the side and should have taken it from the front.
Is handle forward supposed to be hot since it would be on left side and handle pushed away the cold side? No h/c designation of any kind on this Moen.
Richard W. Washington, owner
RW Home Inspections, Inc.
www.RWHOMEINSPECTIONS.com
Texas Real Estate Commission (TREC)
Professional Inspector License #7238
Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter
InterNACHI member since 2004
Based in Katy, serving Houston and all surrounding communities
Need a home inspection in Florida? Check out InterNACHI's listing of Florida certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/6/12, 4:35 PM
Default Re: Are the H/C reversed?
pic did not load
Are the H/C reversed?-dsc08704-jpg
Old 12/6/12, 4:38 PM
Greg W. Mathias, CCHI, CMI's Avatar
Greg W. Mathias, CCHI, CMI Greg W. Mathias, CCHI, CMI is offline
Certified Master Inspector ®
I have found them both ways and asked a couple of plumbers this question. I get different answers. I don't call them up either way as they are not marked. I think when you pull it towards you it should be hot as that would be left if facing the lever.
Greg Mathias, CCHI
Journeyman Carpenter
Level I Thermographer
Global Property Inspections
(780)205-9912
Old 12/6/12, 4:49 PM
Marcel Gratton, CMI's Avatar
Marcel Gratton, CMI Marcel Gratton, CMI is offline
Good question, so I had a look at mine.
This faucet manufacturer indicates forward should be hot at the tub but the opposite at the sink...
I guess it doesn't matter.
Are the H/C reversed?-pic-002-jpg   Are the H/C reversed?-pic-004-jpg   Are the H/C reversed?-pic-006-jpg   Are the H/C reversed?-pic-007-jpg
On The Level Inspection
Gatineau, Québec
Old 12/6/12, 6:55 PM
Gerald L. Coy Gerald L. Coy is offline
My Price Phister back is hot forward is cold
Gerald L. Coy, P.E.
Rochester Home Inspections & Engineering, PLLC
http://rochester-home-inspections.com
Serving Rochester, NY and its metropolitan area.
Old 12/6/12, 7:15 PM
Stephen W. Stanczyk's Avatar
Stephen W. Stanczyk Stephen W. Stanczyk is online now
According to Moen, forward is cold.
Their faucets are manufactured with a label on the hot water line for identification.
Stephen Stanczyk
Pierce County -Thurston County - King County - Kitsap County
Old 12/6/12, 9:07 PM
John Harrison, CMI's Avatar
John Harrison, CMI John Harrison, CMI is online now
I have always found them as hot is back and you cool the water as you pull the handle toward you.
<a href=http://www.bluffshomeinspection.com target=_blank>http://www.bluffshomeinspection.com</a>
Performing Home Inspections in Council Bluffs, Missouri Valley, Glenwood, and surrounding areas
Council Bluffs Home Inspector
Iowa Home Inspector Council Bluffs - Facebook
Active Rain Member
Old 12/7/12, 12:58 AM
Rusty Craig's Avatar
Rusty Craig Rusty Craig is offline
Registered InterNACHI Vendor
I agree with the other posts, cold is towards you and hot is to the back.
EZ Home Inspection Software - Easy to use & Powerful software for home inspectors
$50 off for InterNACHI members.
Discount code: FORNACHI
Toll Free: 888-545-4096
Email: support@ezhomeinspectionsoftware.com
We also offer affordable home inspection websites
Hot Neutral Reversed Recommendations pbreen General Inspection Discussion 6 4/8/11 11:09 PM
reverse polarity?? Scott Schultz Electrical Inspections 33 10/24/07 2:50 PM
Water Heater supply and return reversed dosborne Plumbing Inspections 3 8/5/07 3:08 PM
Recall of Polarity Reversed Outlets Nalliah Thayabharan Electrical Inspections 3 4/20/07 11:50 PM
