Old 6/5/12, 10:25 PM
Richard W. Washington, TREC#7238's Avatar
Richard W. Washington, TREC#7238 Richard W. Washington, TREC#7238 is offline
Default Rinnai tankless wh
Ok folks. The name plate for this 199,000 BTU unit say's for a manufactured home (mobile home). This is installed in a 3600sf single family home built a year ago. Is it that simple that it should not be installed in a slab on grade home? I see tankless about 5% of the time so am just not sure.
Rinnai tankless wh-dsc06511-jpg   Rinnai tankless wh-dsc06512-jpg   Rinnai tankless wh-dsc06510-jpg
Richard W. Washington, owner
RW Home Inspections, Inc.
www.RWHOMEINSPECTIONS.com
Texas Real Estate Commission (TREC)
Professional Inspector License #7238
Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter
InterNACHI member since 2004
Serving Houston and most surrounding communities
Need a home inspection in Massachusetts? Check out InterNACHI's listing of Massachusetts certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 6/5/12, 10:36 PM
Juan C. Jimenez Juan C. Jimenez is offline
Default Re: Rinnai tankless wh
They are definitely good for commercial and residential applications. I am pretty sure it means that it's also certified for, but not limited to, moble home applications
Juan Jimenez
A House on a Rock Home Inspections LLC
God. Family. Home.
804-269-4321
Richmond Home Inspector
Richmond Chimney Sweep
Richmond Radon Testing
Old 6/5/12, 10:53 PM
tHAT'S what I was thinking too Juan. This is the only kind of tankless I have ever seen. There was no problem at any of the fixtures too.
Old 6/5/12, 10:59 PM
Jeffrey R. Pope, CMI's Avatar
Jeffrey R. Pope, CMI Jeffrey R. Pope, CMI is offline
Certified Master Inspector ®
How would it know the difference?
Yes, it means that it is also listed for manufactured homes. Most standard tankless heaters are not listed for RV's, manufactured homes, modular homes or house boats. They must be specifically listed for such applications.
IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE «
Jeff Pope
JPI Home Inspection Service
(661) 212-0738
Los Angeles, Santa Clarita & Antelope Valley CA
Old 6/5/12, 11:30 PM
Thanks for confirming Jeff glad I got this one right
Juan Jimenez
God. Family. Home.
804-269-4321
Old 6/6/12, 12:20 AM
Michael R. Boyett's Avatar
Retired Member
See this Rinnai R94LSi Installation Manual, especially pgs 1,3 & 17. Like said above, it's also certified for mfg home installation as well as stick-builts. Just a funny Japanese way of stating it.
Old 6/6/12, 5:59 PM
Chuck Evans's Avatar
It can be installed in a manufactured home.
The VB series (R75LSi, and R94LSi) are certified for
installation in manufactured (mobile) homes.
Chuck Evans (TREC #7657)
The Woodlands Home Inspection
Houston, TX
_______________________
Awards Committee Member
Tankless water heater issue sstanczyk Plumbing Inspections 18 12/2/10 6:15 PM
Episode 49 - Tankless Water Heaters inxil NACHI.TV Inspection Videos 0 9/10/08 1:59 PM
On Demand Water Heater dgagneur Plumbing Inspections 10 3/30/08 10:57 PM
Home savvy magazine- tankless heaters Brian A. MacNeish Plumbing Inspections 8 3/28/08 8:55 AM
