Old 8/7/12, 10:36 PM
SEAN THORNTON SEAN THORNTON is offline
Default No roof vents
Looked at a house with zero roof vents and there were no visible AAV's. The house was built in 2011 and is on a slab. There were no vents terminating in the attic. Assuming that there are AAV's shouldn't there be at least one main line vent thru the roof?
Need a home inspection in Wyoming? Check out InterNACHI's listing of Wyoming certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 8/7/12, 10:52 PM
Troy N. Pappas's Avatar
Troy N. Pappas Troy N. Pappas is offline
Default Re: No roof vents
Did you look to see if there were any side wall vents?
Safe House Property Inspections
Virginia Beach Home Inspector
Hampton Roads Home Inspector
Professional home inspector serving Virginia Beach, Norfolk, Suffolk, Portsmouth, and Chesapeake 757-418-0944
Old 8/7/12, 10:58 PM
The only side wall vents were for the tankless water heaters
Old 8/7/12, 11:01 PM
Even if they used AAV vents there needs to be an exterior vent.
Old 8/7/12, 11:21 PM
Preston L. Halstead, HI549 Preston L. Halstead, HI549 is offline
They are required to have at least one venting to the exterior.
Preston L. Halstead
VP FL Home & Insurance Inspectors Chapter
Elite Property Inspection & Management
LICENSED GENERAL CONTRACTOR CGC1515203
LICENSED BUILDING INSPECTOR BN6262
LICENSED HOME INSPECTOR HI549
561-420-0277
HOME INSPECTION ~ WIND MITIGATION INSPECTION
Serving Boca Raton, Boynton Beach, Delray Beach, Juno Beach, Jupiter, Lake Park, Lake Worth, Lantana, North Palm Beach, Palm Beach, Palm Beach Gardens, Royal Palm Beach, Wellington, West Palm Beach.
Old 8/7/12, 11:34 PM
Greg W. Mathias, CCHI, CMI's Avatar
Greg W. Mathias, CCHI, CMI Greg W. Mathias, CCHI, CMI is offline
Certified Master Inspector ®
AAV'S??? Cheater valves for drain?
Greg Mathias, CCHI
Journeyman Carpenter
Level I Thermographer
Global Property Inspections
(780)205-9912
Old 8/9/12, 7:26 AM
Curtis Hildebrand Curtis Hildebrand is offline
Send a message via AIM to childebrand
I don't understand. Are you talking about roof vents which condition the attic space or are you talking about plumbing stacks which allow air into the drains?
Kingdom Home Inspections
Old 8/9/12, 9:14 AM
Larry Kage, CMI Larry Kage, CMI is offline
Yes, I had the same question at first. It appears to be the latter.
Awards Committee Member
SUBMIT YOUR AWARD NOMINATIONS HERE:
http://co.nachi.org/inachiawards/
Larry Kage, CMI 2004-2017
State Licensed Builder since 1973
InterNACHI Lifetime Member
~retired~
The above post represents my personal opinion.
Old 8/9/12, 9:24 AM
KEVIN WOOD, CMI KEVIN WOOD, CMI is offline
Banned
Please Note: kwood is a non-member guest and is in no way affiliated with InterNACHI or its members.
Me too!
But I did an inspection of a Metal Roof last week. New Construction and I think it is a good idea to have the "Plumbing Stack Vent" at the highest point out the side of the attic over the end gable vent. This way there is no penetration to the metal roof to deal
with.
I have also seen cheater vents in the attic but I would recommend at least one go to the outside whenever possible.
Old 8/9/12, 11:10 AM
Jeffrey R. Pope, CMI's Avatar
Jeffrey R. Pope, CMI Jeffrey R. Pope, CMI is offline
There are several jurisdictions in my area that allow for a "main AAV" that terminates in the attic, with no outside terminations.
The AAV will be either a 4" or 6" vent, but it is very obvious when you're in the attic.
IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE «
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
New form and pics aalm Florida Home Inspectors 32 2/28/12 10:30 AM
Before You Start Repairing or Replacing Roof Finishes from CMHC mkyriacou Canadian Home Inspectors 0 9/17/09 1:52 PM
Interesting Roof Vents cevans Exterior Inspections 1 6/19/09 3:03 AM
Turbine roof vents phinsperger Exterior Inspections 12 5/10/06 7:57 AM
