This trash can located in a basement has been in use for a long time the kitchen sink drain from above and the washing machine from the basement is discharging into this fancy sump pump pit the pump then discharges into the main above the grade of the basement
Now I have to decide what I want to write about this mess???
They were using a standard submergable sump pump and had cut the original sink drain line and installed the discharge of the pump back to this line.
The basement originally had a floor drain and a stand pipe for the washer but apparently the floor drain line had become stopped up or collapsed no longer in use
</IMG>
