Old 11/8/17, 5:23 PM
Matthew Rotz Matthew Rotz is online now
Default Sump Pump Testing
Hey everyone!
I just wanted to get a feel for how fellow inspectors test sump pumps.
Do you use a stick/hook combo? If so, what is it made from? Electrocution hazards?
Do you prefer to use a bucket full of water? What if the sump is dry with debris/spiderwebs/etc. and looks like it has never had water in it?
Any other testing methods you use?
Thanks!
Parker, Colorado Home Inspector
Need a home inspection in Massachusetts? Check out InterNACHI's listing of Massachusetts certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/8/17, 10:48 PM
Steven E. Bartolomei's Avatar
Steven E. Bartolomei Steven E. Bartolomei is online now
Certified Master Inspector ®
Default Re: Sump Pump Testing
Funny story we have very few basement homes in Arizona, I had a client insist that we test the sump pump so I said you will have to be at the inspection you can climb down in the window well and I will drop the garden hose to you I will be in the basement closet listening for the pump to turn on and the check valve to engage after it turns off. After about 2 minutes I can hear him screaming while rats were running out of the drain in to the window well.
Steven E Bartolomei
US Army Veteran
AZ Lic# 39977
www.jdewey.com
480-239-8526
Old 11/9/17, 5:24 PM
Funny!
Old 11/9/17, 7:39 PM
So nobody tests sump pumps?
Old 11/9/17, 10:45 PM
Dennis DiVito Dennis DiVito is online now
Originally Posted by mrotz View Post
Hey everyone!
Thanks!
I will run both types of pumps, float valve and pedestal by hand. I don't carry a bucket with me to an inspection. I comment if there is water, silt or debris in the pit and the presence of a cover or not. I use a wood stick with a hook at the bottom to lift a float switch if it is underwater. I disclaim the whole thing if the cover is screwed on.
Old 11/13/17, 11:20 AM
Erik Schmidt Erik Schmidt is offline
I lift the float, listen for pump, let it go immediately if pit is dry. No water, no problem. If you did fill the sump pit with water and the pump did not work, what would you do with all that water you just dumped in there?
Erik Schmidt
East Side Home Inspection
Edmonton Alberta
780 477 2666
Old 11/13/17, 1:51 PM
That's what I'm asking!
