Old 10/13/11, 9:23 PM
Eric Hyde Eric Hyde is offline
Default supply line and hot line from water heater both hot
Has anyone ever encountered this? Both the supply water line and the hot water line from the water heater are hot. Any idea why this might be?
Need a home inspection in Kansas? Check out InterNACHI's listing of Kansas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/13/11, 9:30 PM
Roy D. Cooke, Sr's Avatar
Default Re: supply line and hot line from water heater both hot
Is there a circulating pump on the Hot water line ... Roy
http://www.rewci.com/whhohotwaci.html
Click to enlarge and view additional images.
Old 10/13/11, 9:41 PM
Unfortunately, I did not get a picture of the water heater, but I do not remember seeing one.
Old 10/13/11, 10:12 PM
Chuck Evans, TREC 7657's Avatar
Chuck Evans, TREC 7657 Chuck Evans, TREC 7657 is online now
Certified Master Inspector ®
As pressure in the tank rises, some water will move a little ways up the supply line to equalize. Also metal pipes will conduct heat pretty well. How far from the tank did you make your observation? What was the piping material? When you ran hot water in a fixture, did the supply pipe cool down?
Chuck Evans (TREC #7657)
TheWoodlandsHomeInspection.com
Houston, TX
_______________________
Awards Committee Member
Old 10/13/11, 10:18 PM
Great points, Chuck. The lines were your typical copper lines. I didn't check the pipe in conjunction with running the hot water to check for a drop in temp. Will definitely do that next time.
In all, I was wanting to know if this was a deficiency that I should call out. Both replies here have helped. Thanks fellas!
Old 10/13/11, 10:42 PM
Copper is an outstanding thermal conductor
Houston, TX
Old 4/22/12, 6:04 PM
Rick Montgomery Rick Montgomery is offline
Please Note: Rick Montgomery is a non-member guest and is in no way affiliated with InterNACHI or its members.
We just had a cold spell today, so I thought I would check my water heater surface temp and noticed that I get about the same temp (6 degrees difference) on both the supply and outlet lines. Going only 12" up I see a difference of 15 degrees and the gap only includes the farther I go up the lines. This could be both heat transfer through the water as heat rises and equalization. My lines are CPVC which is common for almost all new houses in my area and also is a poor conductor of heat which could point more towards equalization of the tank. All temps were taken without the hot water being used anywhere in the house and the water heater was not running at that moment.
Now to the strange question, should the supply line be insulated at least for 24" to 36", or is that just a waste of money?
Old 4/22/12, 9:48 PM
Jeffrey R. Pope, CMI's Avatar
Jeffrey R. Pope, CMI Jeffrey R. Pope, CMI is offline
Considering the cost of insulating material, I can't say it would be a "waste" of money. If you pay more than a dollar for the insulation, you've probably over paid. However, you will not benefit from adding insulation to the cold water side of the piping.
IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE «
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 4/22/12, 10:47 PM
Chad Norlen, CPI's Avatar
Chad Norlen, CPI Chad Norlen, CPI is offline
Warmer fluids are less dense, so rise. Heat traps would be a good idea.
supply line and hot line from water heater both hot-heat-traps-jpg   supply line and hot line from water heater both hot-plumbed-heat-traps-jpg
Chad Norlen
HVAC Journeyman - State of Idaho
EPA Certified Universal Technician
