Old 5/3/12, 1:12 AM
Richard W. Washington, TREC#7238's Avatar
Richard W. Washington, TREC#7238 Richard W. Washington, TREC#7238 is offline
Default TPR material?
Is this corrugated pipe combined with the pvc ok?
TPR material?-dsc06461-jpg
Richard W. Washington, owner
RW Home Inspections, Inc.
www.RWHOMEINSPECTIONS.com
Texas Real Estate Commission (TREC)
Professional Inspector License #7238
Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter
InterNACHI member since 2004
Serving Houston and most surrounding communities
Need a home inspection in Colorado? Check out InterNACHI's listing of Colorado certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/3/12, 8:39 AM
Joe Funderburk, CMI's Avatar
Joe Funderburk, CMI Joe Funderburk, CMI is online now
Certified Master Inspector
Default Re: TPR material?
I would say that is too many fittings, too many bends, too many restrictions.
Where does it discharge? Is that a garage? If so, it should go to the floor. Technically, the discharge point should be in the same room as the water heater (going through the wall is a code violation).
Theodore Roosevelt
Joe Funderburk, CBO, CMI
Angie's List Super Award Winner 2017, 2016, 2015, 2014, 2013, 2012, 2011, 2010.
Ph: 704-351-1776
www.aohomeinspection.com
Old 5/3/12, 9:41 AM
Jeffrey R. Pope, CMI's Avatar
Jeffrey R. Pope, CMI Jeffrey R. Pope, CMI is offline
Certified Master Inspector ®
Except under the UPC.
PVC is not allowed, but that looks to be CPCV, which is allowed.
I've argued about the flex lines with a few AHJ's. I don't like them, but technically they're allowed as long as they have a continuous downhill slope and no tight bends.
Jeff Pope
JPI Home Inspection Service
(661) 212-0738
Los Angeles, Santa Clarita & Antelope Valley CA
Old 5/3/12, 9:44 AM
William T. Misegades William T. Misegades is offline
I would agree with Joe, however, nowhere is it written how many fittings or bends are allowed on the discharge pipe, but then common sense should prevail.
Here is food for thought... the corrugations reduce the "full size" opening of the discharge pipe. In that case, it would not be allowed in my opinion.
Where there is a Will there is a Way!
Will Misegades
TREC# 10465
RedFish Home Inspections
www.redfishinspections.com
Infraspection Institute Certified Infrared Thermographer Level I # 9631
"it's not just about how to turn on and tune the camera to make pretty colored spots!"
David A. Andersen, Woodlawn, TN
Old 5/3/12, 9:50 AM
Jeffrey R. Jonas's Avatar
Bingo!
Jeffrey R. Jonas
Owatonna, Minnesota
Old 5/3/12, 9:54 AM
Bob Elliott's Avatar
If used or allowed for water supply it is allowed for TPR drain pipe.
Local codes may be different.
I do not like lack of support or going through a wall myself.
Here are the exact codes.(Chicago )
18-29-504.7.1 Discharge.
The discharge from the relief valve shall be piped separately to an indirect waste receptor located inside the building. The discharge shall be piped full size and installed in a manner that does not cause personal injury or property damage and that is readily observable by the building occupants. The discharge from a relief valve shall not be trapped. The diameter of the discharge piping shall not be less than the diameter of the relief valve outlet. The discharge pipe shall be installed so as to drain by gravity flow and shall terminate atmospherically not more than 6 inches (150 mm) above the floor. The end of the discharge pipe shall not be threaded.
18-29-504.8 Required pan.
Water heaters or hot water storage tanks installed in locations where leakage of the tanks or connections will cause damage shall be installed in a galvanized steel or other metal pan of equal corrosion resistance having a minimum thickness of 24 gauge, 0.0276 inch (0.70 mm) Any water heater installed in a cabinet below a counter shall be provided with a drain pan.
Old 5/3/12, 10:00 AM
Too many bends and I do not see the termination.
But it's flexible, and could whip around during release, possibly causing damage to the (C)PVC piping, and potentially harming the occupants!!!
Jeffrey R. Jonas
Owatonna, Minnesota
Old 5/3/12, 10:10 AM
Charles Lambert Charles Lambert is offline
Please Note: clambert2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
The discharge shall be piped full size. The diameter of the discharge piping shall not be less than the diameter of the relief valve outlet.
Bob,
Those two sentences state that the pictured material is not acceptable. The flexible pipe is smaller diameter than the relief valve outlet
Old 5/3/12, 10:21 AM
I agree, and that was my position as well. However, I have been trumped by local officials.
Jeff Pope
(661) 212-0738
Old 5/3/12, 10:30 AM
95% of the homes in this area discharge through the wall. Must be a location thing.
Old 5/3/12, 11:06 AM
OK, little editing to my post...
Nowhere, in the IRC is it mentioned how many fittings or bends are allowed on the discharge pipe.
However, the TRP Valve manufacturers will often times have their own rules and will say the discharge pipe shouldn't be more than 30' and should not have more than 4 elbows as this could cause restrictions and reduce discharge capacity of the TPR.
Here is an example: http://www.cleanmywater.com/dmdocume...ts/1910203.pdf
Page 1 under Installation.
Will Misegades
TREC# 10465
Old 5/3/12, 11:15 AM
Haven't we all
Will Misegades
TREC# 10465
Old 5/3/12, 11:59 AM
2009 IRC P2803.6.1 Requirements for discharge pipe. The discharge
piping serving a pressure-relief valve, temperature relief valve
or combination valve shall:
1. Not be directly connected to the drainage system.
2. Discharge through an air gap located in the same room
as the water heater.
3. Not be smaller than the diameter of the outlet of the
valve served and shall discharge full size to the air gap.
4. Serve a single relief device and shall not connect to piping
serving any other relief device or equipment.
5. Discharge to the floor, to the pan serving the water
heater or storage tank, to a waste receptor or to the outdoors.
6. Discharge in a manner that does not cause personal
injury or structural damage.
7. Discharge to a termination point that is readily observable
8. Not be trapped.
9. Be installed to flow by gravity.
10. Not terminate more than 6 inches (152 mm) above the
floor or waste receptor.
11. Not have a threaded connection at the end of the piping.
12. Not have valves or tee fittings.
13. Be constructed of those materials listed in Section
P2904.5 or materials tested, rated and approved for
such use in accordance with ASME A112.4.1.
Theodore Roosevelt
Ph: 704-351-1776
Old 5/9/12, 12:38 AM
Jim Perp Jim Perp is offline
Please Note: Jim Perp is a non-member guest and is in no way affiliated with InterNACHI or its members.
I Agree with what you are saying and there is a need for the rule to a point.
Old 5/10/12, 11:06 PM
Chuck Evans's Avatar
8. Not be trapped.
Pretty much std practice to pipe them through the wall in the greater Houston market, especially on new construction. Not arguing the IRC reference, but accepted by all AHJs that I know of here.
Chuck Evans (TREC #7657)
The Woodlands Home Inspection
Houston, TX
_______________________
Awards Committee Member
Roofing material ? smcintire Roofing Inspections 6 12/21/11 9:03 AM
wood mosture in LVL material bking General Inspection Discussion 4 7/5/10 2:56 PM
Before You Start Repairing or Replacing Roof Finishes from CMHC mkyriacou Canadian Home Inspectors 0 9/17/09 12:52 PM
Asbestos jlybolt Exterior Inspections 41 7/17/07 1:13 AM
Identify this material tmartens Ancillary Inspection Services 4 5/18/07 9:50 PM
