Old 11/23/17, 11:38 AM
Kevin L. Saunders Kevin L. Saunders is offline
Default TPR Valve Pipe
When the discharge pipe is Horizontal is there a minimum distance before a 90? And is there a limit of how many 90's on a single discharge pipe? Please see photo! Thanks in advance
TPR Valve Pipe-pb210011-jpg
Need a home inspection in Vermont? Check out InterNACHI's listing of Vermont certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/23/17, 11:42 AM
Roy Lewis, CMI's Avatar
Roy Lewis, CMI Roy Lewis, CMI is online now
Certified Master Inspector ®
Default Re: TPR Valve Pipe
As long as it flows by gravity .
InterNACHI Lifetime Member.
www.1stproinspection.com
roy@1stproinspection.com
Serving Gainesville Florida and surrounding areas.
Florida Certified Contractor #CRC1328001
Florida Certified Home Inspector #HI7019
Deus solus me iudicare potest
#1st Pro Inspection
Old 11/23/17, 12:58 PM
Marc A. Goldenberg's Avatar
Marc A. Goldenberg Marc A. Goldenberg is offline
Excessive length over 30' (9.14m), or use of more than four elbows or reducing discharge line size
will cause a restriction and reduce the discharge capacity of the valve
Temperature and Pressure (T&P) relief valves - Support - Water Safety & Flow Control -Watts
TPR Valves and Discharge Piping - InterNACHI
http://www.alltropic.com
Awards Committee Member
The InterNACHI Awards Committee is the final
authority of issuance of any award the committee offers.
Old 11/24/17, 8:37 AM
Michael A. Clark, CMI's Avatar
Michael A. Clark, CMI Michael A. Clark, CMI is online now
4 90's equal one plug
TPR Valve Pipe-plumbing-pipes-jpg
Michael A Clark, Certified Master Inspector«
Inspection Connection
St Albans, West Virginia
"Always tell the truth,
do what you say you will,
and do it Righter than Right...Always"
Facebook
Google Plus
www.charleston-home-inspector.com
www.icwvhomes.com
mclark@icwvhomes.com
Old 11/24/17, 10:33 AM
Gee-zus I can't see thru all that mess but don't see bonding
Old 11/26/17, 10:42 AM
Don C. Hawley Don C. Hawley is online now
Boss said "use as many fittings as possible we charge by the foot and fitting"
