Old 1/25/13, 8:46 PM
David J. Counts, III David J. Counts, III is offline
Default No P-trap? Haven't seen this type of drain before
Has anyone seen this? Shouldn't there be a P-Trap somewhere.
No P-trap?  Haven't seen this type of drain before-sam_2493-jpg
Need a home inspection in Minnesota? Check out InterNACHI's listing of Minnesota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/25/13, 9:05 PM
Chuck Evans's Avatar
Certified Master Inspector ®
Default Re: No P-trap? Haven't seen this type of drain before
Called a bottle trap.
I don't think they are permitted in most jurisdictions. Probably because you cannot rod them (assumption on my part). They're popular when the trap is exposed to view, cause they're purdy.
Chuck Evans (TREC #7657)
TheWoodlandsHomeInspection.com
Houston, TX
_______________________
Awards Committee Member
Old 1/25/13, 9:37 PM
John dematteo John dematteo is offline
Please Note: John dematteo is a non-member guest and is in no way affiliated with InterNACHI or its members.
That is the trap. Usually found on high end sinks
S-Trap? Part2 wmisegades Plumbing Inspections 9 12/12/11 9:07 PM
Floor drain to nowhere backing up ground water or is it sewage? Eliza Fletcher Plumbing Inspections 2 9/22/11 10:56 PM
Pool drain cover recall update llosciale Florida Home Inspectors 2 6/11/11 11:28 AM
Massachusetts Board of Registration of Home Inspectors jtedesco1 Legislation, Licensing, Ethics & Legal Issues for Inspectors 0 2/14/06 4:38 AM
