Old 1/3/11, 12:55 AM
David Pant David Pant is offline
Default Trap weird and crown weir
I am kind of new to all this so please bare with me =).
I am a little confused and could someone help explain this to me.
"Standpipes should extend at least 18 inches and no more than 42 inches above the trap weir."
"The standpipe should be at least 30 inches high measured from the crown weir. "
The way I understood it was the trap weir is the part where the water leaves the trap, and the crown was the highest point of the trap.
Lets say a standpipe was 18" above the trap weir how could it possibly be 30 inches above the crown?
Thanks,
Dave
Need a home inspection in Delaware? Check out InterNACHI's listing of Delaware certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/3/11, 11:58 AM
Jeffrey R. Pope, CMI's Avatar
Jeffrey R. Pope, CMI Jeffrey R. Pope, CMI is offline
Certified Master Inspector
Default Re: Trap weird and crown weir
You're referencing three different dimensions. 18" is the minimum, 42" is the maximum and 30" is "optimal."
The dimension is measured from the top of the weir.
IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE «
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 1/3/11, 12:29 PM
Robert Smith Robert Smith is offline
https://www.nachi.org/gallery/
Trap weird and crown weir-standpipe-1-jpg
INSPECTIONLOGOS.COM
"I can keep explaining it for you, but I can't understand it for you".
Nick G.
Monroe Home Inspection
Old 1/3/11, 12:44 PM
Jeffrey R. Jonas's Avatar
Originally Posted by rsmith24 View Post
David,
FYI... (ref: posted graphic)
Here in the land of basements, the trap is almost always located below the slab (95% of the time).
Always check with your local AHJ for the areas you operate in.
Jeff
PS... Welcome!
Jeffrey R. Jonas
Owatonna, Minnesota
Old 1/3/11, 1:09 PM
Banned
Originally Posted by jjonas View Post
David,
Jeff
PS... Welcome!
Interesting. .........
HERE in the land of basements, the trap is almost always located above the slab (99+% of the time).
Old 1/3/11, 1:11 PM
David OKeefe's Avatar
David OKeefe David OKeefe is online now
This one wasn't in the slab. I called it out as it was only 8" above the the top of the weir. Also I am thinking the tape is not allowed, correct?
Trap weird and crown weir-144-jpg
David
InterNACHI Certified Home Inspector #08051301
NYS Licensed Home Inspector #16000038229
NYS DEC Certified Pest Technician # T4865884
518-505-8305
HouseAbout Home Inspections, LLC
HouseAbout on Facebook
NY Capital Region Chapter InterNACHI
Connect on LinkedIn
Follow HouseAbout_LinkedIn
Follow me on Twitter
HouseAbout_Instagram
Google+
Old 1/3/11, 2:03 PM
Allan Gallatin, #53277 Allan Gallatin, #53277 is offline
They must have funny plumbing sytems in Mn. Here in the other land traps are throughout the the house , where needed !
galaxyhomeinspections.com
An amateur built the Ark !
Professionals built the Titanic !
Old 1/3/11, 2:03 PM
What did you say about the T being horizontal instead of vertical?
INSPECTIONLOGOS.COM
Nick G.
Old 1/3/11, 5:11 PM
So, the question remains, where is the OP located? (That be you David)
Jeffrey R. Jonas
Owatonna, Minnesota
Old 1/3/11, 5:28 PM
Thanks guys I am located in Michigan but will be taking my NHIE exam soon to be able to do inspections in Indiana also.
I just want to make sure and know what I am talking about and to be honest I still think either I dont get it or what I read in the training materials here is not clear.
A response on here says that 30" is optimal but I cut and paste where it says 30" is minimal right out of the NACHI training here.
so still confused heh =)
Thanks,
Dave
Old 1/3/11, 6:05 PM
Thanks,
Dave
A trap is designed to keep sewer gases and airborne bacteria from escaping the drainage system and entering the dwelling. Each plumbing fixture should be separately trapped by a water-seal trap, except as otherwise permitted by the plumbing standard. Fixtures such as water closets and urinals that have integral traps do not require an additional trap installed.
The vertical distance from the fixture outlet to the trap weir should not exceed 24 inches (610 mm). The vertical distance controls the drainage-flow velocity. If the trap has an excessively long vertical separation from the fixture, the velocity of the flow at the trap inlet can create siphoning.
The horizontal distance should not exceed 30 inches (610 mm), as measured from the center line of the fixture outlet to the center line of the inlet of the trap. The horizontal distance from a fixture to the trap limits the amount of bacterial growth and odor. It is desirable to locate the trap as close to the fixture as possible. A fixture should not be double-trapped.
Standpipes should be individually trapped. Standpipes, such as for a clothes washer, should have a minimum height above the trap of 18 inches (457 mm), and a maximum of 42 inches (1,066 mm). Access to all standpipes should be provided for cleaning and rodding.
INSPECTIONLOGOS.COM
Nick G.
Old 1/3/11, 6:22 PM
First I want to say thank you Robert for the illustrations and effort. I feel like I am being a pain in the *** but I dont see where it explains this.
Dave
Old 1/3/11, 7:07 PM
Dave
Where are you getting that quote from? I copied and pasted from the Residential Plumbing Overview for Inspectors
INSPECTIONLOGOS.COM
Nick G.
Old 1/3/11, 7:26 PM
I must confess I did not notice the horizontal T. I see now where it could back up into the standpipe. I shall lookout for this from now on, thank you Robert for pointing this out.
David
518-505-8305
Connect on LinkedIn
Google+
Old 1/3/11, 7:38 PM
Your welcome and when I see homeowner crap like this I also look at/for the cement used and in your attachment I don't see any purple or orange.
INSPECTIONLOGOS.COM
Nick G.
