Old 1/17/13, 8:07 PM
John G. Buckley's Avatar
John G. Buckley John G. Buckley is offline
Default Tripple "T" Wye not?
I'm looking for some opinions on this flue set up. The two flue pipes on the left come from 2 natural draft hot water heaters and the other comes from the furnace at the bottom. All 3 flues connect with T's and I'm concerned about how the furnace flue is across from the hot water heater flue. I would appreciate some input here.
Tripple "T" Wye not?-p1172667-jpg   Tripple "T" Wye not?-p1172666-jpg
John Buckley
20/20 Home Inspection of NJ
1-888-798-5190
2020hinj@gmail.com
WWW.homeinspectorinnj.com
WWW.njmoldtest.com
Old 1/17/13, 9:46 PM
Larry Kage, CMI Larry Kage, CMI is offline
Certified Master Inspector ®
Default Re: Tripple "T" Wye not?
Typically, the smaller vent connector pipe is above: http://www2.iccsafe.org/states/seatt...pendix%20B.pdf
...and the chimney vent pipe may be of insufficient size, etc.
It is worth calling out.
Awards Committee Member
SUBMIT YOUR AWARD NOMINATIONS HERE:
http://co.nachi.org/inachiawards/
Larry Kage, CMI 2004-2017
State Licensed Builder since 1973
InterNACHI Lifetime Member
~retired~
The above post represents my personal opinion.
