Old 12/17/12, 7:40 PM
Richard Murphy Richard Murphy is offline
Default Upside down trap???
Never ran across this one before...Comments???
Need a home inspection in District Of Columbia? Check out InterNACHI's listing of District Of Columbia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/17/12, 7:41 PM
KEVIN WOOD, CMI KEVIN WOOD, CMI is offline
Banned
Please Note: kwood is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Upside down trap???
Richard that is not considered a proper trap anymore! I bet you can just smell the roses on that one.
It was obviously leaking so they turned trap up to fit the bucket in.
Old 12/17/12, 7:48 PM
Marcel R. Cyr, CMI's Avatar
Marcel R. Cyr, CMI Marcel R. Cyr, CMI is offline
Certified Master Inspector ®
Never seen such an array of products to accomplish simple drainage plumbing.
How many different glues did they have anyways?
Lucky the other joints did not leak. The trap was affective before the actual trap.
CMI 2004-2017 Retired
Awards Committee Member
U.S. Member of the Year Winner 2009
45 Years Residential/Commercial Builder
Old 12/17/12, 7:57 PM
Banned
Marcel they went with a Christmas theme! Complete with snow.
Old 12/17/12, 8:11 PM
James F. McKee's Avatar
James F. McKee James F. McKee is online now
that needs replaced Richard...repair by a qualified plumbing contractor nuff said...
Jim McKee
Amherst, Ohio
440 225 8688
www.amhersthomeinspector.com
Old 12/17/12, 8:14 PM
John Ritter John Ritter is offline
Please Note: jritter is a non-member guest and is in no way affiliated with InterNACHI or its members.
Originally Posted by kwood View Post
Richard that is not considered a trap anymore! I bet you can just smell the roses on that one.
Sure it is. It will hold water before the up turn
Old 12/17/12, 8:18 PM
Chris Walsh, CMI's Avatar
Chris Walsh, CMI Chris Walsh, CMI is online now
Chris Walsh
Bracebridge, Ontario.
Retired (from Home Inspections)
Old 12/17/12, 8:24 PM
Banned
OK I should change that to a proper trap! LOL Fixed
Old 12/17/12, 8:35 PM
As John said, it will hold water, but might not function as intended.
Old 12/17/12, 8:39 PM
Yep, I've seen this guy (a re-habber) do no traps and S traps, but this one was his finest hour!!
Old 12/17/12, 8:43 PM
Christopher Currins, CMI Christopher Currins, CMI is offline
Richard that is not considered a proper trap anymore!.
Anymore? When what is ever "consider proper"?
Old 12/17/12, 8:47 PM
Greg W. Mathias, CCHI, CMI's Avatar
Greg W. Mathias, CCHI, CMI Greg W. Mathias, CCHI, CMI is online now
Missed by that much!!!!!
Greg Mathias, CCHI
Journeyman Carpenter
Level I Thermographer
Global Property Inspections
(780)205-9912
Old 12/17/12, 8:49 PM
I agree Chris, I have no idea when that was ever accepted proper.
Old 12/17/12, 8:56 PM
Banned
At one time it did have a proper trap pointing down and could easily be fixed. It does not have to have a clean out if it can be taken apart. I see this set up everyday.
I would be more concerned about the water lines then that mess as it is easy to fix where as who knows what glue they used on all the fittings.
Old 12/17/12, 8:59 PM
Wow, thanks for the explanation.
Condensation Drain line question acassady Inspecting HVAC Systems 26 10/23/14 10:17 AM
S-Trap? Part2 wmisegades Plumbing Inspections 9 12/12/11 8:07 PM
Trap weird and crown weir dpant Plumbing Inspections 22 1/24/11 11:41 PM
Negative angle trap arm issue rlind Plumbing Inspections 4 4/14/06 11:00 PM
