Old 2/20/12, 5:38 PM
Mary Ann Chiquete's Avatar
Mary Ann Chiquete Mary Ann Chiquete is offline
Default Upstairs Moen faucets do not work
Inspected a 4000 sq ft home this morning that had all Moen fixtures in the home. Home is 5 yrs old. PEX type plumbing. Here is the problem; The two faucets in the upstairs master bath did not work at all, also another faucet in bathroom down the hall had VERY low pressure, water just dribbled out. Faucet next to it worked fine. Two other bathroom faucets worked fine. The other problem; No hot water at all four shower mixer valves, cold only. I know that Moen mixer valves can go bad if they sit unused for long periods of time, but all four? Could this be the same problem with the two handle faucets? All fixtures are in excellent condition, like new. I checked all shut valves.
Thank you!
Mary Ann Chiquete
Inspecting Buckeye, Arizona
623-399-7962
www.benchmarkazinspect.com
benchmarkaz@gmail.com
Need a home inspection in Montana? Check out InterNACHI's listing of Montana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/20/12, 5:39 PM
Jeffrey R. Jonas's Avatar
InterNACHI Applicant
Default Re: Upstairs Moen faucets do not work
Did you check the shut off valves at the manifold, or just at the fixtures?
Jeffrey R. Jonas
Owatonna, Minnesota
Old 2/20/12, 5:42 PM
Did not find manifold in home,or at least access to it. I rarely do here in AZ.
Thank you!
Mary Ann Chiquete
623-399-7962
Old 2/20/12, 5:50 PM
If it has PEX, it has a manifold. Not all manifolds use shutoff valves, but for a home that size they are common. It was probably behind an access panel. If you havent filed your report already, I recommend you insert a statement stating that you did not discover the location of the manifold, and to request the location from the seller.
Jeffrey R. Jonas
Owatonna, Minnesota
Old 2/20/12, 5:59 PM
Thanks, I have seen manifold access panels in garages in some homes, but not very often. I even looked in attic. Home is bank owned, so I will just note in report that manifold was not located.
Thank you!
Mary Ann Chiquete
623-399-7962
Old 2/20/12, 6:10 PM
William Warner's Avatar
William Warner William Warner is offline
Failed water softener in the house?
Old 2/20/12, 6:19 PM
Dale Duffy's Avatar
I haven't seen a PEX Manifold in any home built here in the last 10 years. I'd bet its the mixing cartridges, I find they fail especially if the house has sat all last summer during the extreme heat.
Old 2/20/12, 6:43 PM
No water softener installed in home
Thank you!
Mary Ann Chiquete
623-399-7962
Old 2/20/12, 6:46 PM
Thanks Dale, this is what I thought, but it is strange that so many went bad. It just had me scratching my head.
Thank you!
Mary Ann Chiquete
623-399-7962
Old 2/20/12, 6:47 PM
James F. McKee's Avatar
James F. McKee James F. McKee is online now
It's an easy and inexpensive fix on a moen faucet and about all that can go wrong with them...
Jim McKee
Amherst, Ohio
440 225 8688
www.amhersthomeinspector.com
That's interesting. I see the exact opposite here. Perhaps it due to the weather... makes it easier to winterize the home if needed?
I've even seen one extreme case where someone zoned the copper piping! (If I come accross the pic's. I'll come back and post them).
Jeffrey R. Jonas
Owatonna, Minnesota
Old 2/20/12, 6:48 PM
Dale Duffy's Avatar
Mary Ann, I find bad mixing cartridges daily...sometimes 3-4 in a shaq...so what you found is not out of the norm to me.
Old 2/20/12, 6:55 PM
It's a flip of the coin here, but many are still plumbed the traditional way without a manifold.
Old 2/20/12, 7:06 PM
are You seeing much pex there Bill...it's just starting to show up here....
Jim McKee
Amherst, Ohio
440 225 8688
Old 2/20/12, 7:12 PM
Charley L. Bottger's Avatar
Every thing here is PEX now very seldom to see a manifold
http://www.oklahomathermalinfraredimaging.com/
http://www.freedomexpressinspections.com/
Master HVAC Mechanic Retired
Level III Thermographer # 8486 Infraspection Institute
CMI Certified Master Inspector
Residential/Commercial Inspections
Moisture Intrusion Expert Witness
Okla State License # 130
580-268-3340
Upstairs Sewer Gas and Basement Lift Station Merc Man Plumbing Inspections 4 12/24/10 12:29 PM
Homes often are rush jobs, critics assert tmantsch Miscellaneous Discussion for Inspectors 0 3/17/06 7:54 PM
