Old 7/9/12, 2:08 PM
Jeremy E. Ruby's Avatar
Jeremy E. Ruby Jeremy E. Ruby is offline
Default Utility Drain into sump pump
The utility sink drain line is directly going into the sump pump basin. Just wondering if this could be a problem or not. I know its a pretty easy question for some. Also lack of P-trap.
First Priority Home Inspection, LLC
Serving Central Pennsylvania
WWW.PRIORITYHOMEINSPECTIONS.BIZ
Need a home inspection in Pennsylvania? Check out InterNACHI's listing of Pennsylvania certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/9/12, 2:15 PM
Joe Funderburk, CMI's Avatar
Joe Funderburk, CMI Joe Funderburk, CMI is online now
Certified Master Inspector
Default Re: Utility Drain into sump pump
I don't see a problem with it if the sink is infrequently used and the sump discharges into the sewer system.
Theodore Roosevelt
Joe Funderburk, CBO, CMI
Angie's List Super Award Winner 2017, 2016, 2015, 2014, 2013, 2012, 2011, 2010.
Ph: 704-351-1776
www.aohomeinspection.com
Old 7/9/12, 2:17 PM
Thats what I was thinking , just getting another opinion. Thanks Joe
Old 7/9/12, 2:29 PM
Jeffrey R. Jonas's Avatar
InterNACHI Applicant
1) Frequency of use is irrelevent, as well as Seller vs Buyer will be different usage rates, with the Buyer rate yet to be determined,
2) A sump should never be connected to the waste system (unless locally mandated),
3) IMO, due to the possible varied contaminates, (soaps/solvents/feces from dirty diapers/etc.), I would not consider the waste from a utility sink to be simply "grey water".
Jeffrey R. Jonas
Owatonna, Minnesota
Old 7/9/12, 2:31 PM
Originally Posted by jjonas View Post
1) 2) A sump should never be connected to the waste system (unless locally mandated),
A basement sump? Reason?
Theodore Roosevelt
Ph: 704-351-1776
Old 7/9/12, 2:34 PM
Over taxing of the sewage waste systems. I do/have operated in 3 different states, and countless different counties, and every one of them prohibited the practice.
Jeffrey R. Jonas
Owatonna, Minnesota
Old 7/9/12, 2:38 PM
The sump pump isn't connected to the sewage system , pumps it out a PVC discharge pipe into the yard about 15 ft away.
Old 7/9/12, 2:39 PM
Bob Elliott's Avatar
Jeff with no sump it would still go to the house drain so there is no difference though if it is a sump used for flood control and dumping into the ground it would then be an issue.
Where should a 2nd floor slop sink drain to?
Obviously the town drain is above the basement level and a sump is needed.
Old 7/9/12, 2:49 PM
1)
So Jeff, the utility line should drain into the main drainage system?
Old 7/9/12, 2:57 PM
Bob... Chicago terminology may be different from other areas... but in my area, that would be called a "residential lift station" with/without a grinder pump... not a "sump". Sumps generally are for ground water & storm water discharge... irrelevent of where it discharges to.
Jeffrey R. Jonas
Owatonna, Minnesota
Old 7/9/12, 2:57 PM
Yes.
Example... the wifey knocks over a new gallon bottle of bleach in the utility sink and it all drains out before she can contain the spill. Bleach is considered toxic in quantities.
What does your gut tell you?
Jeffrey R. Jonas
Owatonna, Minnesota
Old 7/9/12, 3:01 PM
Yes.
Ok , Then just to be safe, That is what I'm going to recommend that the buyer does. Thank you guys for all the help and very useful info.
Old 7/9/12, 4:35 PM
I assumed that the sump was connected to the sewer or septic system. If not, then the sink should not discharge to it. I agree with others who said that.
Theodore Roosevelt
Ph: 704-351-1776
Old 7/9/12, 5:28 PM
yeah sorry Joe, I should have specified that from the first post.
980 Questions/Answers to the NHIE....Free! jbushart Legislation, Licensing, Ethics & Legal Issues for Inspectors 52 7/11/17 4:34 PM
Basement Sump Pump Drain / Virginia Mike Lester Plumbing Inspections 10 3/12/11 8:26 PM
basement floor Unregistered AskNACHI.org Inspection Questions Forum 4 9/15/10 2:23 AM
Sump Pump vsantos Plumbing Inspections 14 2/25/10 2:37 PM
Sump pump requirements Matthew Klein Plumbing Inspections 0 12/30/09 4:53 PM
