Old 10/2/12, 7:03 AM
Joshua L. Frederick Joshua L. Frederick is online now
Default Vent pipe through lower roof
House with 2 bathrooms, one up/one down (both baths in corners you can see). There was no plumbing vent through upper roof, and only one was the one pictured in lower roof. Technically, vent pipe is above all fixtures in upper bath.
Any reason for concern or would you comment on?
Need a home inspection in Nevada? Check out InterNACHI's listing of Nevada certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/2/12, 8:57 AM
Default Re: Vent pipe through lower roof
Anyone??
Old 10/2/12, 9:40 AM
KEVIN WOOD, CMI KEVIN WOOD, CMI is offline
Banned
Please Note: kwood is a non-member guest and is in no way affiliated with InterNACHI or its members.
Probably an AAV in the attic. If you can't find it allow a Certified Plumber to find it.
Old 10/3/12, 4:08 AM
I looked and did not see any other means of venting.
Old 10/3/12, 4:09 AM
So if the upper bathroom main drain runs through the lower attic into the pictured cast iron stack/vent, this wouldn't be acceptable due to the distance away from the fixtures, correct?
Old 10/3/12, 3:51 PM
O.k. let me rephrase my post a tad, cause I'm having difficulty sorting through all the responses .
If this was at a property you inspected, what would you say in your report regarding plumbing vent?
Old 10/3/12, 4:00 PM
Greg W. Mathias, CCHI, CMI's Avatar
Greg W. Mathias, CCHI, CMI Greg W. Mathias, CCHI, CMI is offline
Certified Master Inspector ®
So you are saying that the upper floor is venting through the lower floor vent stack on the roof? I am not sure how it could be. I would call for further evaluation on this. How did the tub or shower drain under a load of water?? I will fill a sink and bath tub up and drain them at the same time just to see how they work together. If they drain slow or bubble and suck then I call them up for evaluation.
Greg Mathias, CCHI
Journeyman Carpenter
Level I Thermographer
Global Property Inspections
(780)205-9912
Old 10/3/12, 4:06 PM
Yes, or at least appeared that way.
Everything drained fine and/or normal
This was what I did.
Old 10/3/12, 4:18 PM
Bob Elliott's Avatar
OK smart a-s-s lol
So is the top of that PVC vent above the bathroom fixtures and how far distant to the lower roof vent as there is a limit as to how far you can go horizontally.
A couple well placed arrows like I hope you do in a report would help.
Old 10/3/12, 4:26 PM
[QUOTE=belliott;953488]
[QUOTE]
Quite a ways away (the whole lower roof).
[QUOTE=belliott;953488] as there is a limit as to how far you can go horizontally.
[QUOTE]
What is that limit?
Old 10/3/12, 4:37 PM
Oh now you want me to work for you ,OK was hoping not to need looking this up.
First gotta be at least 10 feet from that window...check.
Old 10/3/12, 4:39 PM
On the bright side, once you let me know, I'll be a smarter ***
Old 10/3/12, 4:45 PM
905.1 All vent and branch vent pipes shall be free from drops and sags, and each such vent
shall be level or shall be so graded as to drip back by gravity to the drainage pipe it serves.
The vent pipe cannot have a drop or a sag.
The horizontal vent pipe can be installed level and does not need a fall or 1/4 inch per foot.
When you install a horizontal vent pipe with 1/4 inch fall, the slope shall be graded so the
water flows into the drain pipe.
Old 10/3/12, 4:46 PM
905.3 Unless prohibited by structural conditions, each vent shall rise vertically
to a point not less than 6 inches above the flood-level rim of the fixture served
before offsetting horizontally, and whenever two or more vent pipes converge,
each such vent pipe shall rise to a point at least 6 inches in height above the
flood-level rim of the plumbing fixture it serves before being connected to any
other vent. Vents less than 6 inches above the flood-level rim of the fixture shall
be installed with an approved drainage fittings, material, and grade to the drain.
Old 10/3/12, 4:54 PM
See 31-2
http://www2.iccsafe.org/states/virgi...2031_Vents.pdf
A little on the Commercial side of things. mcyr General Inspection Discussion 457 8/1/09 10:50 AM
Replacing slate roof - whether to vent new asphalt one or not Barbara Turnham Exterior Inspections 0 3/23/09 11:55 AM
Improper pluming vent through roof. momalley Plumbing Inspections 0 5/20/07 9:25 PM
Gas and oil hot water tank and Boiler Share Vents hvanderbeek Miscellaneous Discussion for Inspectors 8 1/25/07 5:22 PM
