Old 2/7/13, 11:19 AM
Jonathan M. Cartwright Jonathan M. Cartwright is offline
Default Vent and ??? in street vault
This assembly is common in some south Reno neighborhoods.
What is it?
I see it usually in cul-de-sacs but not always at the end.
Thanks.
Vent and ??? in street vault-p1302164-jpg   Vent and ??? in street vault-p1302165-jpg
Grush Inspections, LLC
www.grushinspections.com
775-323-1117 phone
775-323-8117 fax
775-287-1932 cell
Serving Reno/Sparks, Carson City, Fernley and all surrounding areas.
Home, Termite/Pest, Fireplace/Chimney, and HVAC Inspections.
Need a home inspection in District Of Columbia? Check out InterNACHI's listing of District Of Columbia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/7/13, 11:24 AM
David P. Valley's Avatar
Certified Master Inspector
Default Re: Vent and ??? in street vault
What is it?
Thanks.
Water supply disconnect
Old 2/7/13, 11:36 AM
This is not a disconnect - no valve. The disconnect is in the round vault to the left in photo #1.
775-323-1117 phone
775-323-8117 fax
775-287-1932 cell
Fire caused by Faulty Dryer Vent nhagarty Ancillary Inspection Services 1 3/7/12 9:27 AM
Pellet stove help chellickson General Inspection Discussion 23 8/19/10 2:23 AM
Air admittance valves everywhere apfaff Plumbing Inspections 13 4/16/07 10:17 AM
Gas and oil hot water tank and Boiler Share Vents hvanderbeek Miscellaneous Discussion for Inspectors 8 1/25/07 6:22 PM
