Old 6/29/12, 7:18 PM
Juan C. Jimenez Juan C. Jimenez is offline
Default Washer machine drain pan
Need a little help here
This was a second floor washing machine drain pan. I scoured my code books and the internet and could not find anywhere that this was a requirement and I could not find much info on a properly installed drain pan. This pan had a little pipe welded on to it. A hole was drilled in the floor. The pvc ran all the way into the crawlspace. I know it should not drain into the crawlspace but where else would it go? Should it be installed to drain into the homes drainage system? outside?
Washer machine drain pan-laundryroom-jpg
Washer machine drain pan-laundryroom2-jpg
Washer machine drain pan-laundryroom3-jpg
Washer machine drain pan-laundryroom4-jpg
Juan Jimenez
A House on a Rock Home Inspections LLC
God. Family. Home.
804-269-4321
Richmond Home Inspector
Richmond Chimney Sweep
Richmond Radon Testing
Need a home inspection in California? Check out InterNACHI's listing of California certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 6/29/12, 7:20 PM
Default Re: Washer machine drain pan
Oh and it didnt seem to go all the way into the pvc. It could potentially drain into the floor cavity below if it was not dropped in just right.
Juan Jimenez
God. Family. Home.
804-269-4321
Old 6/29/12, 9:25 PM
Marcel R. Cyr, CMI's Avatar
Marcel R. Cyr, CMI Marcel R. Cyr, CMI is offline
Certified Master Inspector ®
Should just be removed and repaired.
Drain pans are just that, a pan to catch any incidental minor water leaks that may come about.
Once visible, it gets repaired.
It is not designed for a constant leak and if it were, it would drain to the outside or to a fixture that is already trapped.
CMI 2004-2017 Retired
Awards Committee Member
U.S. Member of the Year Winner 2009
45 Years Residential/Commercial Builder
Old 6/29/12, 9:33 PM
Jeffrey R. Jonas's Avatar
As Marcel said.
Think of it to be like a drain pan for a WH. It may never be used, but it's there just in case.
Jeffrey R. Jonas
Owatonna, Minnesota
Old 6/29/12, 9:35 PM
Bob Elliott's Avatar
I recommend drain pans for all washers in a location where damage could be caused from spills.
No different from a Hot Water Heater but simply not covered by code.
http://www.repairclinic.com/PartDeta...Pan/WX7X1/2800
drain pan for washer
Old 6/29/12, 9:40 PM
Michael Larson's Avatar
Michael Larson Michael Larson is online now
If the washer is above a finished area it needs drain pan.
As a Professional Home Inspector, I support the privacy of my clients.
You own your private information. I won't sell or give away yours, others do
www.InspectraPro.com
www.MinnesotaHomeInspector.biz
Michael Larson
Hudson, WI
Call me
Old 7/15/12, 10:06 AM
Shawn Tyler Shawn Tyler is offline
Please Note: Shawn Tyler is a non-member guest and is in no way affiliated with InterNACHI or its members.
Many houses have these kind if issues, so it is always recommended to have a proper home inspection by a certified home inspector before selling and buying a new home.
Old 7/15/12, 12:52 PM
Harold Robinson Harold Robinson is offline
YES!!
Advantage Home Inspections, Inc
863-228-2801
Old 7/15/12, 12:57 PM
No ****...
Juan Jimenez
God. Family. Home.
804-269-4321
Old 7/15/12, 2:32 PM
William T. Misegades William T. Misegades is offline
Originally Posted by jjimenez View Post
No ****...
Where there is a Will there is a Way!
Will Misegades
TREC# 10465
RedFish Home Inspections
www.redfishinspections.com
Infraspection Institute Certified Infrared Thermographer Level I # 9631
"it's not just about how to turn on and tune the camera to make pretty colored spots!"
David A. Andersen, Woodlawn, TN
Old 7/15/12, 4:13 PM
David C. Macy, CMI's Avatar
David C. Macy, CMI David C. Macy, CMI is offline
Here are some illustrations you can use for the washing machine overflow.
That is an improper discharge in the crawl.
The one today discharged nicely from the 2nd floor into the garage with an indirect connection, garage had a floor drain.
I am with the no **** on the inspection.
Washer machine drain pan-laundry-standpipe-jpg   Washer machine drain pan-leaky-washer-jpg   Washer machine drain pan-leaky-washer-illustration-jpg   Washer machine drain pan-218812-007-jpg   Washer machine drain pan-218812-025-jpg
Old 7/15/12, 4:21 PM
Thanks David. Excellent graphics.
Juan Jimenez
God. Family. Home.
804-269-4321
Washer Drain Pipes Rebecca Jennifer Plumbing Inspections 0 4/21/11 11:35 PM
Condensate Drainage jevans Inspecting HVAC Systems 28 11/27/10 2:55 PM
Washer Drain thejnicki Plumbing Inspections 8 12/1/06 6:22 AM
Washer Secondary Drain roconnor Plumbing Inspections 7 4/2/06 1:02 PM
