Old 4/20/17, 9:39 PM
David OKeefe's Avatar
David OKeefe David OKeefe is online now
Default No water at exterior bibs
Inspection today was at a one year home that was the model home for a development. Exterior frost free bibs also with shutoff valves in the basement that were turned off at the inspection. I turned on the valves but I could not get any water to flow out of the exterior bibs (2). Cannot figure it out except that the bibs may be clogged? The home is on a well with no filtration system in place. Any ideas?
David
InterNACHI Certified Home Inspector #08051301
NYS Licensed Home Inspector #16000038229
NYS DEC Certified Pest Technician # T4865884
518-505-8305
HouseAbout Home Inspections, LLC
HouseAbout on Facebook
NY Capital Region Chapter InterNACHI
Connect on LinkedIn
Follow HouseAbout_LinkedIn
Follow me on Twitter
HouseAbout_Instagram
Google+
Need a home inspection in Nevada? Check out InterNACHI's listing of Nevada certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/21/17, 11:15 AM
Joshua L. Frederick Joshua L. Frederick is online now
Default Re: No water at exterior bibs
You did your job and then some. Let someone else figure it out.
http://northwestohiohomeinspector.com
Defiance home inspector
Northwest Ohio home inspector
Old 4/21/17, 12:43 PM
Just couldn't figure it out. Rest of the faucets and plumbing worked fine.
David
518-505-8305
Connect on LinkedIn
Google+
Old 4/21/17, 1:11 PM
Stephen W. Stanczyk's Avatar
Stephen W. Stanczyk Stephen W. Stanczyk is online now
Some newer homes have a 2nd water meter and shut off valve for outside / irrigation lines. Check by the street meter for a second control box.
Some newer homes also have interior shut off valves for exterior valves. I have found them in upstairs bedroom cabinets and most of the time in garages.
Stephen Stanczyk
Pierce County -Thurston County - King County - Kitsap County
Old 4/21/17, 10:28 PM
John Paul de Oliveira's Avatar
John Paul de Oliveira John Paul de Oliveira is offline
There might be a separate shut off valve for the basement shutoff valves, saw it one time up in the mountains here. The valves notoriously do not fully shut off, so an extra one to make sure there is no partial leak. If the frost free hose bib is angled slightly upwards it will still freeze and split.
Old 4/21/17, 11:50 PM
This was well water so no 2nd meter. I also followed the lines in the basement looking for perhaps an extra shutoff but only found one each for the exterior bibs. when I turned them on I could hear the water run through the lines to the exterior bibs. It's a mystery. I recommended a plumber to figure it out. I'll contact the client in a couple of weeks to see what happened.
David
518-505-8305
Connect on LinkedIn
Google+
Old 4/22/17, 8:58 AM
Andrew Sleezer Andrew Sleezer is offline
Sometimes on the spring loaded kind when they are not used for a long time the washer sticks. Particularly if water is off... if they turn on and wait may fix itself.
