Old 5/26/12, 11:11 AM
John Safstrom John Safstrom is offline
Default water heater drain valve plumbing ?? any ideas
I couldn't figure out what I found attached to this water heater yesterday. The pictures aren't very good, but the drain valve on the water heater was connected to a pipe that has a pressure valve and an Intermatic timer (like you find on a pool pump motor). The pipe then disappeared into the wall. Any ideas on what that would be?
I also added a last pic of the pex line that was attached on top and the water line for the icemaker to the garage fridge.
John Safstrom
TREC #10566
Systematic Home Inspections, PLLC
Allen,TX
www.systematichomeinspections.com
john@systematichomeinspections.com
Need a home inspection in Virginia? Check out InterNACHI's listing of Virginia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/26/12, 11:34 AM
Jeffrey R. Pope, CMI's Avatar
Jeffrey R. Pope, CMI Jeffrey R. Pope, CMI is offline
Certified Master Inspector ®
Default Re: water heater drain valve plumbing ?? any ideas
Hot-water loop, aka hot-water recirculation system.
The timer is set so that the hot water circulates at specific times during the day, such as 20 or 30 minutes prior to taking your morning shower.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 5/26/12, 11:38 AM
Robert Ernst Robert Ernst is offline
Jeff is right on. The only other time I have seen that is when the water heater was used for heating. In that situation the water heater is designed for heating and often there is a sticker that identifies that.
Nevada Inspector of Structures #1730
Nevada Energy Auditor #30
www.homecsi.com
Old 5/26/12, 12:34 PM
Juan C. Jimenez Juan C. Jimenez is offline
Why would you need hot water recirculation for a system with a storage tank? I know they install them on tank less water heaters to save water that would be wasted while waiting for the water to warm up. Same idea?
Juan Jimenez
A House on a Rock Home Inspections LLC
God. Family. Home.
804-269-4321
Richmond Home Inspector
Richmond Chimney Sweep
Richmond Radon Testing
Old 5/26/12, 1:25 PM
Thanks Jeff, I didn't think of that. Seems like overkill to me.
John Safstrom
TREC #10566
Allen,TX
Old 5/26/12, 1:47 PM
ROBERT YOUNG's Avatar
ROBERT YOUNG ROBERT YOUNG is online now
Location: Ville de Montréal - Borough Côte-des-Neiges-Notre-Dame-de-Grâce
Check the fittings.
ZURN have the class action suite going.
That vent stack does not look right. I will look at it later.
Is the home or a room being heated with this recirculation set-up.
Only one hot water tank?
Robert Young's
Montreal Home Inspection Services Inc.
Our Motto: Putting information where you need it most, "In Your Hands."
https://montreal-home-inspection-services.com
home-inspectionservices.com
I received this email about Ontario Certified Master Inspector Roy Cooke
Old 5/26/12, 2:14 PM
Originally Posted by jjimenez View Post
Same idea?
Yes, same idea.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Whats Wrong with this WH? jfunderburk Plumbing Inspections 37 4/4/12 9:50 AM
TPR valve acox Plumbing Inspections 19 5/27/07 1:36 PM
TPR & Combusiton Air thejnicki Plumbing Inspections 16 9/18/06 9:55 PM
small valve on cold water supply ahead of water heater? Walt Hoffman Plumbing Inspections 6 1/23/06 8:44 AM
