Old 2/19/12, 5:35 PM
David Nasser's Avatar
David Nasser David Nasser is offline
Default Does a Water heater need to be in an enclosure if installed outside?
Unit was installed on the side of the house....The unit was turned on
but was not working...like the pilot had been blown out by the wind.
Which is making me ask the question...
An Ounce of prevention is better
than a pound of cure :}
www.pyramid-home-inspections.net
Need a home inspection in Vermont? Check out InterNACHI's listing of Vermont certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/19/12, 6:14 PM
Bob Elliott's Avatar
Default Re: Does a Water heater need to be in an enclosure if installed outside?
Lol.
JOKE RIGHT?
Old 2/19/12, 6:16 PM
No... need the truth. I usually see them in a metal enclosure.
Old 2/19/12, 6:22 PM
Christopher Currins, CMI Christopher Currins, CMI is offline
Certified Master Inspector ®
What does vent pipe connect to?
Old 2/19/12, 6:25 PM
Eave....hardware attached to the eave....
Old 2/19/12, 6:27 PM
James F. McKee's Avatar
James F. McKee James F. McKee is online now
We see nothing like that up here Dave....just can't keep that water from freezing in the winter time....
Jim McKee
Amherst, Ohio
440 225 8688
www.amhersthomeinspector.com
Old 2/19/12, 6:28 PM
Robert W. Newland, JR.'s Avatar
Robert W. Newland, JR. Robert W. Newland, JR. is offline
Dave, I did a quick search on a couple of mfg's istallation manuals and they both said they must be installed indoors. Looks like your picture has the base of a metal closet(?)
Robert Newland, CMI
Tyrone, GA 30290
NACHI05101290
http://www.CertifiedHI.com
http://www.HomeInspectorTyroneGa.com
Home Inspection Reports Powered by:
HomeGauge eServices
Old 2/19/12, 6:35 PM
It looks very dangerous to me, in several ways.
Old 2/19/12, 7:55 PM
Charles Lambert Charles Lambert is offline
Please Note: clambert2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
It appears that there was a metal enclosure around it, the base is still in place. See it all the time in older areas here. Recommend they replace the enclosure
Old 2/19/12, 8:17 PM
Ok back in and I will not even comment on the goofy thing past how it it takes to burn down the house.
Unlit pilot may be a blessing or is it now safe to have fire pits on the wall?
Old 2/19/12, 10:14 PM
Robert Ernst Robert Ernst is offline
I have never seen a non tankless made for exterior installation. I have seen small water heaters installed outside like this in warmer climates but most always they are in some sort of shed or closet.
Nevada Inspector of Structures #1730
Nevada Energy Auditor #30
www.homecsi.com
Old 2/19/12, 10:17 PM
Bob,
To see a water heater on the exterior of an older home around here (So Cal) is very, very common. I agree not the best set up but very common. They make metal enclosures (that are crap) for such installations. Of the hundreds maybe thousands I have seen none are installed correctly, saw three last week. They can be installed outside here because our weather is much more mild than elsewhere in the country.
Old 2/20/12, 12:08 AM
Dale Duffy's Avatar
I see them installed like this often at an old property, I don't believe there is anything wrong with it, they installed tens of thousands like that in the greater Phoenix area in the 50's and 60's, some people just replace them when they fail, but install them at the same location with no enclosure.
Old 2/20/12, 1:21 AM
So it is OK to have a flaming burner (gas) right up against a flammable siding?
Bunch of idiots would allow that.
No gas water heater is allowed to be in contact with a wall even inside where wind will not fan a flame as here.
That flex line looks very stressed
Old 2/20/12, 1:40 AM
Dale Duffy's Avatar
The burner is probably a foot from the siding?
If a type-B Vent is going through the eave with one inch clearance, what's the problem?
It might be a Masonry Wall too, most older homes were built properly.
Pool/Spa Inspection contract. jdobbs Florida Home Inspectors 11 10/6/12 7:07 PM
Sulphur smell bsmith Plumbing Inspections 2 6/6/08 9:32 PM
Water heaters in attics phughes Plumbing Inspections 1 1/11/07 12:08 PM
