Old 1/20/19, 11:25 PM
David Nasser's Avatar
David Nasser David Nasser is offline
Default Water Heater Overflow Pipe material ?
Water Heater Overflow Pipe material ?-deidra-riverside-069-jpgWater Heater Overflow Pipe material ?-deidra-riverside-066-jpg
Is this blue plastic pex piping ok to be used as an overflow pipe ?
An Ounce of prevention is better
than a pound of cure :}
www.pyramid-home-inspections.net
Need a home inspection in Utah? Check out InterNACHI's listing of Utah certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/20/19, 11:43 PM
Chuck Evans's Avatar
Certified Master Inspector ®
Default Re: Water Heater Overflow Pipe material ?
I've never seen a water heater with an overflow pipe.
The PEX material is suitable for use as a T&P relief discharge, of course, there are many other factors to consider before deciding it's OK as implemented.
Is that a direct CSST connection to the gas control valve?
Chuck Evans (TREC #7657)
The Woodlands Home Inspections
Magnolia TX Home Inspections & Thermography
Houston, TX
_______________________
Awards Committee Member
Old 1/21/19, 9:59 PM
Thanks
Old 1/26/19, 11:04 AM
Charley L. Bottger's Avatar
In my area Blue PEX is not allowed on a water heater relief valve. Blue is cold water only. We use Red PEX, CPVC plastic and or metal only as a downspout. Blue PEX and PVC plastic is not rated for hot water.
http://www.oklahomathermalinfraredimaging.com/
http://www.freedomexpressinspections.com/
Master HVAC Mechanic Retired
Level III Thermographer # 8486 Infraspection Institute
CMI Certified Master Inspector
Residential/Commercial Inspections
Moisture Intrusion Expert Witness
55 years in the Trades
Okla State License # 130
580-268-3340
Old 1/26/19, 12:55 PM
Bradley K. Toye, CMI's Avatar
Bradley K. Toye, CMI Bradley K. Toye, CMI is online now
Should be 1" PEX due to fitting restriction. That's the code in my area.
Brad K Toye
ITC/FLIR Level I Building Investigation Thermographer
FL Certified Building Contractor CBC034303
FL Certified Home Inspector HI 391
FL Certified Mold Assessor MRSA 589
727-403-5029
Lecsi2@gmail.com
Old 1/26/19, 1:03 PM
Joe Funderburk, CMI's Avatar
Joe Funderburk, CMI Joe Funderburk, CMI is online now
Rated PVC and any other material approved for use as distribution piping is acceptable for a TPR pipe. This plastic pipe however is too close to the draft hood/flue.
T. Roosevelt
Joe Funderburk, CBO, CMI
Angie's List Super Award Winner 2018, 2017, 2016, 2015, 2014, 2013, 2012, 2011, 2010.
Ph: 704-351-1776
www.aohomeinspection.com
Old 1/26/19, 4:58 PM
Originally Posted by badair View Post
someone is feeding a bunch of hokum
red, white, and blue PEX pipe are all rated the same
Uponor PEX carries the following hydrostatic temperature and pressure ratings.
200°F (93.3°C) at 80 psi
180°F (82.2°C) at 100 psi
120°F (48.9°C) at 130 psi (½" tubing only)
73.4°F (23°C) at 160 psi
In accordance with ASTM F876 Standard Specification for Cross-linked Polyethylene (PEX) Tubing, the excessive temperature and pressure capability for Uponor AquaPEX® is 210°F (99°C) at 150 psi.
BA I don't make the rules I just follow them. Water temp from a relief valve can exceed 210F
580-268-3340
Old 1/26/19, 5:02 PM
PVC schedule 40 in my area is not allowed for a downspout as the rating is 180 degrees F
580-268-3340
Old 1/26/19, 10:02 PM
Ian W. Mayer, CMI's Avatar
Ian W. Mayer, CMI Ian W. Mayer, CMI is online now
As Chuck said, that is NOT an overflow pipe.
And you are in California.
PEX is not listed as an approved material for TPR discharge pipe in the California Plumbing Code. Though there is a provision for "other" which leaves a bit of a grey area.
