Old 5/12/12, 12:49 PM
Jeffrey Chase's Avatar
Jeffrey Chase Jeffrey Chase is offline
Default Water Heater vent through side of house
Is it permitted that a natural draft gas water heater exhaust vent through the side of a house? What would you recommend in your report if you saw this?
Need a home inspection in Colorado? Check out InterNACHI's listing of Colorado certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/12/12, 12:58 PM
David A. Andersen, TN HI# 40's Avatar
David A. Andersen, TN HI# 40 David A. Andersen, TN HI# 40 is offline
Default Re: Water Heater vent through side of house
Does it have an induced draft in the flue?
"working together to get-IR-done" Chris Walsh
Bracebridge, Ontario:
BPI# 5015804
Old 5/12/12, 1:10 PM
Thanks for the reply. No -it is just natural drafting.
Old 5/12/12, 1:17 PM
Christopher Currins, CMI Christopher Currins, CMI is offline
Certified Master Inspector ®
Do you have a photo?
Old 5/12/12, 1:20 PM
No I don't. In hindsight, I should have taken one.
Old 5/12/12, 1:41 PM
If the water heater has a draft hood, a "natural draft" type water heater, not induced draft or a power vent, it is required to be connected to the chimney, which could be a b-vent.
Old 5/12/12, 1:52 PM
Did the exhaust look similar to this?
water-heater-vent-through-side-house-hpim9982.jpg   water-heater-vent-through-side-house-hpim9984.jpg
Old 5/12/12, 1:54 PM
Chris - thanks for the advice and your fast reply.
Old 5/12/12, 1:57 PM
There is no draft fan and the vent goes through the block wall near the top below the sill plate.
Old 5/12/12, 1:58 PM
Larry Kage, CMI Larry Kage, CMI is offline
From Hart & Cooley Installation Instructions:
Hart & Cooley Type B gas vent pipe and fittings are
Underwriters Laboratories-tested and listed to
Standard 441 for use with listed gas-fired appliances
that have been certified for use with Type B gas vent.
B-Vent is intended for neutral or negative draft
applications. It is designed for vertical installations
(including laterals) but may be used for horizontal
applications with a draft-inducing fan located such
that all indoor portions of the vent are under negative
pressure.
http://www.hartandcooley.com/Libraries/Product_Installation/3_-12_in_Instructions.sflb.ashx
Awards Committee Member
Larry Kage, CMI 2004-2017
State Licensed Builder since 1973
InterNACHI Lifetime Member
~retired~
The above post represents my personal opinion.
Old 5/12/12, 2:01 PM
Michael Larson's Avatar
Michael Larson Michael Larson is online now
Unlikely.
If you have the water heater make and model, check the installation guide.
As a Professional Home Inspector, I support the privacy of my clients.
www.InspectraPro.com
www.MinnesotaHomeInspector.biz
Michael Larson
Hudson, WI
Call me
Old 5/12/12, 2:19 PM
I am disappointed that the Nachi plumbing course water heater section doesn't address this (that I could find). Is this something a home inspector should know or is it considered a specialty?
Old 5/12/12, 2:25 PM
It's something every home inspector should know.
Have you taken this one yet?
http://www.nachi.tv/water-heaters/in...ater-tanks.htm
Old 5/12/12, 2:45 PM
Unfortunately the Nachi TV course doesn't address this either. I wasn't able to find anything relevant on the Nachi.org web site and am also disappointed in that. Larry identified a good resource.
Gentlemen - thank you for all your info and help.
Old 5/12/12, 2:59 PM
Jeffrey R. Jonas's Avatar
Yes... even educators fall into this scenario from time to time...
"You don't know, what you don't know, until you know it".
Jeffrey R. Jonas
Owatonna, Minnesota
Dual Water Heaters - parallel or series gmelien Plumbing Inspections 25 9/27/17 10:51 AM
Water heater side vent clearance requirments sfogarty Plumbing Inspections 9 3/9/12 7:49 AM
