Old 5/23/12, 5:21 PM
Jeffrey A. Prince Jeffrey A. Prince is offline
Default Water service entry and sewer
Has anyone have any input on this. House was built in 1978.
Water service entry and sewer-100_3347-jpg   Water service entry and sewer-100_3348-jpg
Safe At Home Inspections,Inc.
Home Inspections performed in Darien, Downers Grove, Lisle, Westmont, Woodridge, Naperville, Aurora, and all surrounding areas in Greater Chicagoland.
630-437-1572
Need a home inspection in Maryland? Check out InterNACHI's listing of Maryland certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/23/12, 10:52 PM
KEVIN WOOD, CMI KEVIN WOOD, CMI is offline
Banned
Please Note: kwood is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Water service entry and sewer
You are missing the bond between the meter for EGC. Sometime they attach it on the right side shown and forget to check if it goes back to ground with no bond then EGC is broken.
I also would recommend support blocks under each end to take the weight of the the elbow fittings.
Water service entry and sewer-grounding-jumper-jpg
Old 5/24/12, 9:11 AM
Ground is connected on the street side of the meter
630-437-1572
Old 5/24/12, 9:15 AM
Juan C. Jimenez Juan C. Jimenez is offline
Would you need a bond there since it is before the meter?
Old 5/24/12, 9:18 AM
Have you ever seen a set up like that with the water entry like that right with sewer line? I am under the impression that no jump is needed when you are on the street side of the meter correct?
630-437-1572
Old 5/24/12, 11:15 AM
Chad Norlen, CPI's Avatar
Chad Norlen, CPI Chad Norlen, CPI is offline
The GEC is bonded to the water distribution system to provide a solid path to the source to open the OPD in the event a metal pipe becomes energized. It is not there to ground the electrical system to earth. Hence the jumper provides the SOLID connection around the meter, water heater, softener, or other equipment that may not provide a reliable connection and allow the metal pipes to remain energized and use you to complete the circuit.
Around here, they want the gas distribution system bonded for the same reason.
Coincidentally, EC&M is hosting a webinar today on grounding and bonding hosted by Mike Holt. Wish I could attend, but I have to work.
Chad Norlen
HVAC Journeyman - State of Idaho
EPA Certified Universal Technician
Old 5/24/12, 11:22 AM
Jeffrey R. Pope, CMI's Avatar
Jeffrey R. Pope, CMI Jeffrey R. Pope, CMI is offline
Certified Master Inspector
Generally, there is no issue with these pipes being side-by-side except when placed in a trench. When place in a common trench, there is a separation requirement and/or a material-listing requirement, neither of which would apply here.
If it were copper and cast-iron, you would need separation between the dissimilar metals.
IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE «
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 5/24/12, 11:51 AM
Banned
Chad I have the video and if you promise not to copy it you can view on a shared platform. You make the call and I will allow you to view it.
Old 5/27/12, 4:18 PM
I found this reference today from EC Mag's website, thought it applied here:
Grounding path continuity
In a recent Code question, you stated that, no matter which side of the water meter you bonded to, you had to bond around it. In our area, the meters are located near the street. There is more than 10 feet of pipe in the ground before it enters the house. Why is the bond required?
The continuity of the grounding path shall not rely on water meters. This information may be found in NEC 250.53. To be permitted for use as a grounding electrode, the grounding path requires 10 feet or more of underground metal water pipe in direct contact with the earth. So, in your area, they don’t have water meters in the house. Well, you don’t have to bond around something that’s not there. NEC 250.50 describes the grounding--electrode system. In your question, the metal underground water pipe qualifies as a grounding electrode and must be supplemented by an additional electrode, which generally satisfies the required concrete-encased electrode.
Chad Norlen
Old 5/28/12, 12:42 PM
Wayne B. Wilson, TN 439's Avatar
Wayne B. Wilson, TN 439 Wayne B. Wilson, TN 439 is online now
You should still have with cooper and galvanized also (dissimilar metals.) also the white deposit tell me there is a leak . My questions is way would they use galvanize pipe in 1978?
Wayne Wilson CMI
East TN Home Inspections LLC
865-256-1490
https://www.myhomeinspection.net/
New article on sewer gases in the home inxil Home Inspection Blogs 0 9/24/10 4:20 PM
Renovating Your Basement for Livability mkyriacou Canadian Home Inspectors 0 10/22/09 12:45 PM
