Water shutoff valve Type?
Anyone know what type of shutoff valve this is? Would you recommend it be replaced with a ball valve?
Well if I am not mistaken, that is the meter above to the right. This is a common brass meter ball valve attached to the meter riser. (An HB-2) Same type as you would find at a modern street meter just with a handle installed. FORD was the giveaway.
It does not turn you left the handle up, I believe, to shut off water
It is a ball valve. The handle rotates 90 degrees to turn it Off.
You believe? I gave you the friggin part number. It is a ball valve. :roll:
Stephen- I would give you my opinion on what it is, but you’d get all crankie on me because you took the part number and looked it up and I on the other hand will damn well stand behind my wild *** guess and post something stupid and have to run off to may safe space and chill for the rest of the day! ](*,)
LOL. How you feeling Dave?
Hope all is well Dave as much as can be.
Hanging in there Marcel. Thanks!
Being ornery as ever Stephen! :twisted:
That’s our Dave.
I can’t imagine what you’re going through. Best to you, buddy. :slight_smile:
